IMAP configuration problem...
kotso
Hello...
I'm new to DirectAdmin and mail servers... Before I had web server but not mail.
So after installing DA I cant log on mail...
I get
Error connecting to IMAP server: localhost.
111 : Connection refused
So i checked forum and tryed to do these:
./build update_dovecot
./build dovecot
./build todovecot
/etc/rc.d/init.d/dovecot restart
echo "action=delete&value=mbox" >> /usr/local/directadmin/data/task.queue
everything was fine and currently devecot is running on my server.
Info: I dont use xinitd and I have not installed this...
then I tryed to do this:
./set_permissions.sh email
but script gave error:
Can't open /etc/xinetd.conf: No such file or directory.
xinetd: unrecognized service
but still created IMAPD at /usr/sbin/
I tryed to connect from outlok but I get error like pass is not correct...
and in /var/log/maillog I found following error:
Apr 13 18:49:47 *** dovecot[2159]: auth(default): passwd-file(***@***.**,1.2.3.4): unknown user
Apr 13 18:49:47 *** dovecot[2159]: auth(default): shadow(***@***.**,1.2.3.4): unknown user
System is fedora 6.
SElinux disabled...
on firewall following ports are open: 21, 22, 25, 53, 80, 110, 143, 443, 953, 2222
Please advise what to do...
Constantin
Try this:
wget -O /etc/dovecot.conf http://files.directadmin.com/services/customapache/dovecot.conf
service dovecot restart
I tryed but not helped.... and also in log i did not see any more
tthis lines....
Now I just can not log and no log file is updated....
last what i see in log file is:
Apr 13 19:15:39 geons dovecot[2159]: Killed with signal 15
Apr 13 19:15:40 geons dovecot[31302]: Dovecot v1.0.rc29 starting up
