janneman1966
- Jan 14, 2014
I'm trying to install DA on Ubuntu Server 13.10 (VPS).
Did install the pre-install requirements, filled out client/license-id, choose option 4 (Custombuild 2 beta) etc.
Everything seems to work fine, but after a while 3 bells are ringing and I get these errormessages and installation stops:
Did try the php recompiling
but can't get any further...
Tried installing on Ubuntu Server 13.10/13.04 and Debian 7 (all x86 and x64 versions tried).
Please can anybody help me on how to proceed now?
In file included from progname.c:26:0:
./stdio.h:1010:1: error: 'gets' undeclared here (not in a function)
_GL_WARN_ON_USE (gets, "gets is a security hole - use fgets instead");
make[2]: *** [progname.o] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/libiconv-1.14/srclib'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/local/directadmin/custombuild/libiconv-1.14/srclib'
make: *** [all] Error 2
Cannot find /usr/local/bin/php
Please recompile php with custombuild, eg:
./build all d
This appears to be a 64-bit system.
a common cause of http/php compile failures is mentioned here:
http://help.directadmin.com/item.php?id=213
./build all d
