i need some help with SSL installing, beucase i don't know why i can make it.
So, i have user called "tt33" which i created through admin level, so i don't have any reseller.
1. Admin Level -> IP Management -> i choose admin here and click on assign button
2. Reseller Level -> List Users -> tt33 -> Modify User username, and here i have "Set IP To: 1.1.1.1(example) tt33's current IP" and "Current IPs: 1.1.1.1(example), IP Type: Main".
Then i log in with tt33 user and go to:
1. Advanced features ->SSL Certificates and i get error "you can only add a certificate if you own the ip you are using:"
And now i really don't understand where is the catch, because i think i did everything correctly?
I want to note that my machine is VPS, and i have only 1IP, but support of my hosting told me:
"You already have dedicated IP. It is your main VPS IP address and you should be able to use it for your website SSL hosting. You can host 1 SSL protected website per 1 dedicated IP address. If you need to host second SSL protected website, then you need second IP address."
So can u give me some good advice how to make it work?
