Internal IP changed after losing power and rebooting. Centos 8
cbar
Hi, guys, I lost connectivity to the server, all domains down, ,and after login back on the machine found out that the machine ip changed by running
/sbin/ifconfig
so, I went into the router and changed as well and then run cd/ usr/local/directadmin/custombuild
./build rewite_confs
problem resolved but how can I avoid the machine Ip changing again?
thank you for your help!
ip not change if you use static ip
in this case, you are using dynamic ip
try config static ip in your server.
( should config with ssh console )
Thanks,
