SupermanInNY
- Sep 28, 2004
I got a lot of error msgs (and also got kicked out of my network - TG for KVM-OverIP) of:
ip_conntrack: table full, dropping packet.
I googled around and found that the value in ip_conntrack_max is probably not big enough and I need to increase it.
Given the answer in: http://support.imagestream.com/Resolving_ip_conntrack_table_full_Errors.html
It is a simple value change.
BUT,.. here is my problem:
server.com:/proc/sys/net/ipv4 # cat /proc/sys/net/ipv4/ip_conntrack_max
cat: /proc/sys/net/ipv4/ip_conntrack_max: No such file or directory
The directory has lots of files,.. except that one file.
OK,. let me vi /proc/sys/net/ipv4/ip_conntrack_max
NOPE.. can't do this!
It won't let me Write, no :wq! commands.
server.com:/proc/sys/net/ipv4 # less /etc/fstab
# This file is edited by fstab-sync - see 'man fstab-sync' for details
LABEL=/ / ext3 defaults,usrquota,grpquota 1 1
LABEL=/boot /boot ext3 defaults 1 2
none /dev/pts devpts gid=5,mode=620 0 0
none /dev/shm tmpfs defaults 0 0
LABEL=/home /home ext3 defaults,usrquota,grpquota 1 2
none /proc proc defaults 0 0
none /sys sysfs defaults 0 0
LABEL=/tmp /tmp ext3 defaults,nosuid,noexec 1 2
LABEL=/usr /usr ext3 defaults 1 2
LABEL=/var /var ext3 defaults 1 2
LABEL=SWAP-sda5 swap swap defaults 0 0
/etc/fstab (END)
server.com:/proc/sys/net/ipv4 # uname --all
Linux server.com 2.6.9-55.0.12.ELsmp #1 SMP Fri Nov 2 11:19:08 EDT 2007 i686 i686 i386 GNU/Linux
I tried to be 'sneaky' about it and create it elsewhere and move it:
server.com:/home/alon # mv ip_conntrack_max /proc/sys/net/ipv4/
mv: cannot create regular file `/proc/sys/net/ipv4/ip_conntrack_max': No such file or directory
Any pointers?
-Alon.
/etc/fstab (END)
Any pointers?
-Alon.
