hi
i use last directadmin
Let's encrypt client 2.0.24 has been installed.
/usr/local/directadmin/scripts/letsencrypt.sh renew 'crm.teleservice.ir' 4096 /usr/local/directadmin/data/users/telircocrm/domains/crm.teleservice.ir.san_config /var/www/html
Incorrect Usage: flag provided but not defined: -preferred-chain
NAME:
lego run - Register an account, then create and install a certificate
USAGE:
lego run [command options] [arguments...]
OPTIONS:
--no-bundle Do not create a certificate bundle by adding the issuers certificate to the new certificate.
--must-staple Include the OCSP must staple TLS extension in the CSR and generated certificate. Only works if the CSR is generated by lego.
2021/11/20 11:33:48 flag provided but not defined: -preferred-chain
Certificate generation failed.
NAME:
USAGE:
OPTIONS:
