mailscanner problem
pilpelet
Hello to all ,
I bascily tring to install mailscanner and virus scanning .
Maybbe someone will be able to help
There is a thread regarding this and went step by step , it was all installed and configured , the related services are running ok
but the scanner dont scan the mails .
by reading the posts i gatherd that no one realy tested it all and gave the right and easy way to install and config mailscanning on exim .
the thread is here
http://www.directadmin.com/forum/showthread.php?s=&threadid=1187
Any help will be great .
Thanks ,
Try posting to the thread itself so that if there are any mistakes, then can be corrected for anyone else following that thread.
Hi john ,
I will , the server is realy starting to go crazy from all the viruses fload , i gave it 10 hours yesterday without any success .
Regards ,
I've removed your other threads, Please don't create duplicates in other sections (this thread and a post in the guide should be adequate)
Thanks,
Chris
I'm not farmiliar with Mailscanner. Please post a *reply* to the mailscanner thread (not a new thread) and perhaps someone there can help you figure out what's setup incorrectly :)
