Major Problems
sysc
Well, I had a cpanel server before and decided to make the switch. My site is base soley on oscomerse with a very large DB backend. I backed up the site and moved it over. Imported the DB using SQL-Front. Now im having TONS of problems with the oscomerse parsing errors, tons of normal table graphs showing on the site as code.. Do I need to install a fresh oscommerse or what? Support even thought I payed for it is nearly IMPOSSIBLE to get from DA. Ive called and emailed and get nothing.
