Message system, cron and others not working
Status
Not open for further replies.
ericovk
Rotterdam, Netherlands
Since the installation of directadmin, some services are not working at all. The message system and create backups for example.
All services under Service Monitor are running normal.
I looked in a dozen log files and figured out that for some reason yum erased a lot of services.
Apr 26 14:24:46 Erased: matahari
Apr 26 14:24:46 Erased: system-config-firewall-base
Apr 26 14:24:47 Erased: git
Apr 26 14:24:48 Erased: perl-Git
Apr 26 14:24:48 Erased: iwl5150-firmware
Apr 26 14:24:48 Erased: iwl100-firmware
Apr 26 14:24:49 Erased: iwl6050-firmware
Apr 26 14:24:49 Erased: bfa-firmware
Apr 26 14:24:50 Erased: iwl6000-firmware
Apr 26 14:24:50 Erased: iwl1000-firmware
Apr 26 14:24:50 Erased: dracut-kernel
Apr 26 14:24:51 Erased: dracut
Apr 26 14:24:51 Erased: aic94xx-firmware
Apr 26 14:24:52 Erased: iwl6000g2a-firmware
Apr 26 14:24:52 Erased: b43-openfwwf
Apr 26 14:24:52 Erased: iwl6000g2b-firmware
Apr 26 14:24:53 Erased: matahari-broker
Apr 26 14:24:53 Erased: matahari-host
Apr 26 14:24:54 Erased: matahari-network
Apr 26 14:24:55 Erased: matahari-service
Apr 26 14:24:55 Erased: qpid-cpp-server-ssl
Apr 26 14:24:55 Erased: matahari-sysconfig
Apr 26 14:24:56 Erased: matahari-agent-lib
Apr 26 14:24:56 Erased: crontabs
Apr 26 14:24:57 Erased: cronie-anacron
Apr 26 14:24:58 Erased: qpid-cpp-server
Apr 26 14:24:59 Erased: cyrus-sasl
Apr 26 14:24:59 Erased: plymouth
Apr 26 14:25:00 Erased: policycoreutils
Apr 26 14:25:01 Erased: openssh-server
Apr 26 14:25:01 Erased: mdadm
Apr 26 14:25:02 Erased: libdrm
Apr 26 14:25:02 Erased: rsyslog
Apr 26 14:25:03 Erased: qpid-qmf
Apr 26 14:25:04 Erased: qpid-cpp-client-ssl
Apr 26 14:25:05 Erased: kbd
Apr 26 14:25:05 Erased: iptables-ipv6
Apr 26 14:25:06 Erased: dhclient
Apr 26 14:25:06 Erased: quota
Apr 26 14:25:07 Erased: systemtap
Apr 26 14:25:07 Erased: openssh-clients
Apr 26 14:25:08 Erased: openssh
Apr 26 14:25:08 Erased: util-linux-ng
Apr 26 14:25:09 Erased: iputils
Apr 26 14:25:09 Erased: udev
Apr 26 14:25:10 Erased: initscripts
Apr 26 14:25:11 Erased: iproute
Apr 26 14:25:11 Erased: iptables
Apr 26 14:25:26 Installed: iptables-1.4.7-5.1.el6_2.x86_64
Apr 26 14:25:51 Installed: iproute-2.6.32-17.el6.x86_64
Apr 26 14:25:51 Installed: iputils-20071127-16.el6.x86_64
Apr 26 14:25:53 Installed: util-linux-ng-2.17.2-12.4.el6.x86_64
Apr 26 14:25:54 Installed: initscripts-9.03.27-1.el6.centos.1.x86_64
Apr 26 14:25:55 Installed: udev-147-2.40.el6.x86_64
Apr 26 14:25:56 Installed: openssh-5.3p1-70.el6_2.2.x86_64
Apr 26 14:25:56 Installed: openssh-server-5.3p1-70.el6_2.2.x86_64
Apr 26 14:31:58 Installed: iptables-1.4.7-5.1.el6_2.x86_64
Apr 26 14:32:42 Installed: nano-2.0.9-7.el6.x86_64
Apr 26 15:49:31 Installed: mdadm-3.2.2-9.el6.x86_64
May 04 13:21:51 Installed: openssh-clients-5.3p1-70.el6_2.2.x86_64
As you can see, some were installed again, most were not. Strangely enough some of messages are also echoed in /var/log/messages
Apr 26 14:00:09 hosted-by kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Apr 26 14:24:46 hosted-by yum[6891]: Erased: matahari
Apr 26 14:24:46 hosted-by yum[6891]: Erased: system-config-firewall-base
Apr 26 14:24:47 hosted-by yum[6891]: Erased: git
Apr 26 14:24:48 hosted-by yum[6891]: Erased: perl-Git
Apr 26 14:24:48 hosted-by yum[6891]: Erased: iwl5150-firmware
Apr 26 14:24:48 hosted-by yum[6891]: Erased: iwl100-firmware
Apr 26 14:24:49 hosted-by yum[6891]: Erased: iwl6050-firmware
Apr 26 14:24:49 hosted-by yum[6891]: Erased: bfa-firmware
Apr 26 14:24:50 hosted-by yum[6891]: Erased: iwl6000-firmware
Apr 26 14:24:50 hosted-by yum[6891]: Erased: iwl1000-firmware
Apr 26 14:24:50 hosted-by yum[6891]: Erased: dracut-kernel
Apr 26 14:24:51 hosted-by yum[6891]: Erased: dracut
Apr 26 14:24:51 hosted-by yum[6891]: Erased: aic94xx-firmware
Apr 26 14:24:52 hosted-by yum[6891]: Erased: iwl6000g2a-firmware
Apr 26 14:24:52 hosted-by yum[6891]: Erased: b43-openfwwf
Apr 26 14:24:52 hosted-by yum[6891]: Erased: iwl6000g2b-firmware
Apr 26 14:24:53 hosted-by yum[6891]: Erased: matahari-broker
Apr 26 14:24:53 hosted-by yum[6891]: Erased: matahari-host
Apr 26 14:24:53 hosted-by dbus: [system] Reloaded configuration
Apr 26 14:24:54 hosted-by yum[6891]: Erased: matahari-network
Apr 26 14:24:54 hosted-by dbus: [system] Reloaded configuration
Apr 26 14:24:55 hosted-by yum[6891]: Erased: matahari-service
Apr 26 14:24:55 hosted-by dbus: [system] Reloaded configuration
Apr 26 14:24:55 hosted-by yum[6891]: Erased: qpid-cpp-server-ssl
Apr 26 14:24:55 hosted-by yum[6891]: Erased: matahari-sysconfig
Apr 26 14:24:56 hosted-by yum[6891]: Erased: matahari-agent-lib
Apr 26 14:24:56 hosted-by yum[6891]: Erased: crontabs
Apr 26 14:24:57 hosted-by yum[6891]: Erased: cronie-anacron
Apr 26 14:24:58 hosted-by qpidd[1231]: 2012-04-26 14:24:58 notice Shut down
Apr 26 14:24:58 hosted-by yum[6891]: Erased: qpid-cpp-server
Apr 26 14:24:59 hosted-by yum[6891]: Erased: cyrus-sasl
Apr 26 14:24:59 hosted-by yum[6891]: Erased: plymouth
Apr 26 14:25:00 hosted-by yum[6891]: Erased: policycoreutils
Apr 26 14:25:01 hosted-by yum[6891]: Erased: openssh-server
Apr 26 14:25:01 hosted-by yum[6891]: Erased: mdadm
Apr 26 14:25:02 hosted-by yum[6891]: Erased: libdrm
Apr 26 14:25:02 hosted-by kernel: Kernel logging (proc) stopped.
Apr 26 14:25:02 hosted-by rsyslogd: [origin software="rsyslogd" swVersion="4.6.2" x-pid="1086" x-info="http://www.rsyslog.com"] exiting on signal 15.
As a pretty newbee, I am not really sure whether I just have to yum install these services in CentOS (6.2 x64) to get my DirectAdmin working as it should? Help would be really appreciated. :o
Ai, I see my previous reply didn't make it through the forum. I hate these random questions you have to fill in if you want to post a message.
I don't receive messages from my DirectAdmin panel. For example: when someone tries to do a Brute Force Attack for the 100th time.
Cron jobs also don't work
Backups / restore function doesn't work at all.
It's pretty nasty.
As you can see I have installed the Brute Force Monitor by the DirectAdmin manual.
I also upgraded PHP to version 5.3.12.
The random question appear just untill a moderator / admin check you as real user, sorry but is for prevent spammers.
1 - Check which email is set to the system message center (top right). Check if mail server is working, check logs
2 - How can you say they doesnt work? How cron would be related to DA? It is just system related
3 - As ive asked.. why it doenst work? How can you say that? What did you tryed?
And, most important, did you reade guide? http://help.directadmin.com and www.site-helper.com?
BFM is not get installed manually, the scripts to make action are made manually, BFM exist as default.
Regards
Thanks for the quick reply.
The email address in the message system is okay. But it's not that I only don't get an email. But there are no messages appearing in the message system when I start a backup of a user account.
I've just tried to make a backup via: Admin Backup/Transfer > selected a user and checked the location (/home/admin/admin_backups) and submitted.
When I login with ssh, there are is nog .tar.gz file appearing (nor a folder that indicated that DirectAdmin is processing the backup) in the folder /home/admin/admin_backups.
And there are no messages appearing in the Message System (0 new)
There is an old backup of may 6. But I can't remember how that got there. :(
I don't see a way to edit my forum message.
Anyway, I've just checked some logs:
Apache error log:
[Thu May 10 16:47:58 2012] [error] [client 61.51.18.235] File does not exist: /var/www/html/user
[Thu May 10 16:47:58 2012] [error] [client 61.51.18.235] File does not exist: /var/www/html/404.shtml
The latest logs from /var/log/cron dates from April 26
The backup is not immediate, but should be that cron isnt working and so backup arent starting.
Please post out for those commands:
cat /usr/local/directadmin/data/task.queue
cat /etc/cron.d/directadmin_cron
ps aux | grep crond
Regards
action=directadmin&value=restart
action=backup&local%5Fpath=%2Fhome%2Fadmin%2Fadmin%5Fbackups&owner=admin&select%30=die&type=admin&value=multiple&when=now&where=local
action=backup&select%30=autoresponder&select%31=database&select%31%30=vacation&select%32=domain&select%33=email&select%34=emailsettings&select%35=forwarder&select%36=ftp&select%37=ftpsettings&select%38=list&select%39=subdomain&type=sitebackup&value=haa
* * * * * root /usr/local/directadmin/dataskq
2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue;
#5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a;
10 0 * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue
0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue
ps aux | grep crond
admin    24274  0.0  0.0 103308   888 pts/0    S+   17:20   0:00 grep crond
Cheers!
Ok, your cron isnt running.
run:
/etc/init.d/crond restart
then again post output for:
ps aux | grep crond
Regards
Could you tell me (for my understanding) what > /usr/local/directadmin/data/task.queue does/means?
crond restart gives: bash: /etc/init.d/crond: No such file or directory
It's simply removed. (like in my first post: removed by Yum) But I just don't know why or how?
I think there's more missing. Can't I just simply install the missing things with yum install, or does this conflict with DirectAdmin?
This is what's installed:
root@d1:/etc/init.d ssh$ ls
auditd exim iptables messagebus netconsole rdisc udev-post
da-popb4smtp functions iptables.backup mysqld netfs single
directadmin halt killall named network sshd
dovecot httpd mdmonitor named.back proftpd startips
Regards!
Sorry, tabs got messed up:
etc/init.d$ ls -1
auditd
da-popb4smtp
directadmin
dovecot
exim
functions
halt
httpd
iptables
iptables.backup
killall
mdmonitor
messagebus
mysqld
named
named.back
netconsole
netfs
network
proftpd
rdisc
single
sshd
startips
udev-post
the line you asked remove everything in the specified file, cause there was 5 backup request in it.
ok so, install it
yum install crond -y
Regards
thnx guys
I was already googling because crond wasn't working.
I think the hosting company installed the CentOS 6.2 minimal version. Do you know if there are other services that I need to install to let DirectAdmin work properly?
Cheers!
Status
