mq_exim_max_load_size - where?
Migdiradmin
Where to change this limit ?
Queue size (xxx) is larger than the maximum value (2000) and may timeout
I try to find mq_exim_max_load_size=in directadmin.conf but i didnt found.
Regards
it's default value
try
/usr/local/directadmin c | grep mq_exim_max_load_size
if you want to change just add it into that file
mq_exim_max_load_size=3000
it's default value
try
[root@server /]# /usr/local/directadmin c | grep mq_exim_max_load_size
Returned this:
-bash: /usr/local/directadmin: Is a directory
worked with
[root@server directadmin]# /usr/local/directadmin/directadmin c | grep mq_exim_max_load_size
mq_exim_max_load_size=2000
But now what i have to do?
