MYSQL error when doing backup: (Errcode: 24) when using LOCK TABLES
albatroz
Peru
I am trying to backup a kind of huge database 8MB but every time I use
mysqldump -p --opt xxxxxxxxx
I get the following error:
mysqldump: Got error: 1105: File './admune_clarodb/c_142_pages.MYD' not found (Errcode: 24) when using LOCK TABLES
Any ideas?
What would happen if zip the directory where the MySQL database files are located?
/var/lib/mysql/xxxxx
will that work?
Yes ...
but maybe no.
If you're going to/from the same OS distribution, and the same version of MySQL, absolutely.
But it's not supported.
And to do it that way you'd have to shut down MySQL for everyone long enough to back it all up.
i have an idea that works for me and i created backup successfully;)
cd /var/lib/mysql/database_name
find your file (MYD) inside and check ls -al for chmod :)
propably (MYD file) not gonna have -rw-rw---- like others files inside
just make chmod 660 your_problematic_file.MYD
then /etc/init.d/mysql restart
after that in direct admin in user account make chceck then repair database in directadmin
after that make backup and it will be without errors :)
thats all folks! ;)
