Mysql not connecting urgent
ssgill
Hello, since this morning mysql is not connecting. Its running but incorrect socket
mysqld.service - MySQL database server
Loaded: loaded (/etc/systemd/system/mysqld.service; enabled; vendor preset: enabled)
Active: activating (start) since Thu 2023-05-11 11:22:38 MDT; 451ms ago
Process: 14281 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 14282 ExecStartPre=/bin/sh -c [ ! -e /usr/local/mysql/bin/galera_recovery ] && VAR= || VAR=`cd /usr/local/mysql/bin/..; /usr/local/mysql/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_POSITION
Main PID: 14307 (mysqld)
Status: "Starting final batch to recover 214 pages from redo log"
Tasks: 15 (limit: 4915)
Memory: 74.1M
CGroup: /system.slice/mysqld.service
└─14307 /usr/local/mysql/bin/mysqld --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Uses event mutexes
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Number of pools: 1
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Using SSE2 crc32 instructions
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Completed initialization of buffer pool
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=140993460115
May 11 11:22:38 matrix.mydomain.com mysqld[14307]: 2023-05-11 11:22:38 0 [Note] InnoDB: Starting final batch to recover 214 pages from redo log.
my.cnf
[mysqld]
max_allowed_packet=64M
local-infile=0
innodb_file_per_table
sql_mode=""
socket=/usr/local/mysql/data/mysql.sock
[client]
ls -la /var/lib/mysql/mysql.sock
srwxrwxrwx 1 mysql mysql 0 May 11 11:28 /var/lib/mysql/mysql.sock
netstat -lnp | grep mysql
// empty no response
ps ax | grep mysql
14322 pts/1 S+ 0:00 systemctl status mysqld
26544 ? Ssl 0:00 /usr/local/mysql/bin/mysqld --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock
26582 pts/0 S+ 0:00 grep mysql
27002 pts/2 S 0:00 su -l mysql -s /bin/bash
I have tried changing the socket in my.cnf to /var/lib/mysql/mysql.sock, but still not able to connect.
Thanks for your help.
wait till restore finish:
Thanks for the quick reply, but it keeps on crashing during restore and i guess its one database that's doing this. How can i remove this one database for new and see if it mysql goes on line.
Do you have enough harddisk space ? I have seen MySQL doing weird things of that in the past
Status
â— mysqld.service - MySQL database server
Active: activating (auto-restart) (Result: signal) since Thu 2023-05-11 11:53:29 MDT; 1s ago
Process: 9589 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 9590 ExecStartPre=/bin/sh -c [ ! -e /usr/local/mysql/bin/galera_recovery ] && VAR= || VAR=`cd /usr/local/mysql/bin/..; /usr/local/mysql/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_POSITION=
Process: 9614 ExecStart=/usr/local/mysql/bin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock (code=killed, signal=ABRT)
Process: 9647 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Main PID: 9614 (code=killed, signal=ABRT)
Status: "Taking your SQL requests now..."
df -lh
Filesystem Size Used Avail Use% Mounted on
udev 7.8G 0 7.8G 0% /dev
tmpfs 1.6G 109M 1.5G 7% /run
/dev/mapper/matrix--vg-root 23G 12G 11G 52% /
tmpfs 7.8G 196K 7.8G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/sda2 471M 84M 363M 19% /boot
/dev/mapper/matrix--vg-var 9.1G 7.8G 841M 91% /var
/dev/mapper/matrix--vg-tmp 1.8G 236K 1.7G 1% /tmp
/dev/sda1 511M 5.8M 506M 2% /boot/efi
/dev/mapper/matrix--vg-home 1.1T 423G 585G 42% /home
tmpfs 1.6G 0 1.6G 0% /run/user/1000
tmpfs 1.6G 0 1.6G 0% /run/user/1004
It start's and then crashed system status
Active: active (running) since Thu 2023-05-11 12:05:00 MDT; 405ms ago
Process: 16970 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 16971 ExecStartPre=/bin/sh -c [ ! -e /usr/local/mysql/bin/galera_recovery ] && VAR= || VAR=`cd /usr/local/mysql/bin/..; /usr/local/mysql/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_POSITION
Process: 17028 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Main PID: 16995 (mysqld)
Tasks: 31 (limit: 4915)
Memory: 107.3M
├─16995 /usr/local/mysql/bin/mysqld --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock
└─17029 addr2line -C -f -e /lib/x86_64-linux-gnu/libpthread.so.0
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: 2023-05-11 12:05:00 0 [Note] Plugin 'FEEDBACK' is disabled.
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: 2023-05-11 12:05:00 0 [Note] Server socket created on IP: '::'.
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: 2023-05-11 12:05:00 0 [Note] Reading of all Master_info entries succeeded
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: 2023-05-11 12:05:00 0 [Note] Added new Master_info '' to hash table
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: 2023-05-11 12:05:00 0 [Note] /usr/local/mysql/bin/mysqld: ready for connections.
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: Version: '10.4.27-MariaDB' socket: '/var/lib/mysql/mysql.sock' port: 3306 MariaDB Server
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: 2023-05-11 12:05:00 0 [Note] InnoDB: Buffer pool(s) load completed at 230511 12:05:00
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: mysys/stacktrace.c:175(my_print_stacktrace)[0x56377dc42abe]
May 11 12:05:00 matrix.mydomain.com systemd[1]: Started MySQL database server.
May 11 12:05:00 matrix.mydomain.com mysqld[16995]: sql/signal_handler.cc:232(handle_fatal_signal)[0x56377d686c7f]
lines 1-24/24 (END)
you can try force recovery one of modes, step by step lower it. there must be more info in mysql log.
I am going to get databases from the backup, what would be the best way to start over. Remove current mysql and reinstall, debian latest.
Followed but old data still exists, any way to remove old databases.
Where do they exist? Did you stop mysql/mariadb first and then to this?
mv /var/lib/mysql /var/lib/mysql.old
or if you have old backups delete the /var/lib/mysql directory?
If yes, then all old databases should be one. Remember to set mysql_backup to no before installing again.
Only other backups can exist here:
/usr/local/directadmin/custombuild/mysql_backups/
Thanks, everything is going in circles. i did it before but i guess i missed one step my mysql directory is in home
/home/mysql
its symlinked to /var/lib/mysql
so i moved /home/mysql-backup
remove symlink
and reinstalled and mysql is running now.
Thanks for your support. Staring backup
