ramnathero
- May 18, 2007
Hello!
my server is running with DirectAdmin and for some reason the Named 9.3.4 is *** Stopped *** and i was reboot several time and check. i still facing the same problem and i cannot start the Named 9.3.4. every time i try to start i getting a error message like following.
An error has occurred
Details
/sbin/service named start 2>&1
is there is anyone tell me how to solve this problem. i need to fixed asap. so every help is thankfuls.
this is only happen after i installed ffmpeg, ffmpeg-php and all codecs, flvplayer2 also i renumber i mistaken and installed git. i think the git may cause this problem if is that the problem how can i solve it. i dont know how to uninstall git too.
when i used ssh to run the starting command i get like folloing.
[root@lsn]# service named start
Starting named:
Error in named configuration:
zone localhost/IN: loading master file localhost.zone: file not found
_default/localhost/IN: file not found
zone 0.0.127.in-addr.arpa/IN: loading master file named.local: file not found
_default/0.0.127.in-addr.arpa/IN: file not found
zone lsn-d1698.limestonenetworks.com/IN: loaded serial 2008081300
zone mydomain.com/IN: loaded serial 2008081401
zone mydomain.net/IN: loaded serial 2008082300
[FAILED]
thank you and looking forward asap.
Details
Starting named:
[FAILED]
