named problem
Reikor
http://thednsreport.com/?domain=teraserver.com.ar
Parent pass NS records at parent servers Your NS records at the parent servers are:
ns1.retina.ar. [ 200.10.202.3 ]
ctina.ar. [ 200.16.97.17 ]
merapi.switch.ch.
ns.UU.NET.
relay1.mecon.gov.ar. [ 168.101.16.10 ]
athea.ar. [ 200.16.98.2 ]
[These were obtained from ns-ar.ripe.NET.]
warn Glue at parent nameservers WARNING. The parent servers (I checked withns-ar.ripe.NET.) are not providing glue for all your nameservers. This means that they are supplying the NS records (host.example.com), but not supplying the A records That may cause some extra miliseconds in DNS. This will usually occur if your DNS servers are not in the same TLD as your domain
NS info NS records at your nameservers Your NS records at your nameservers are:
200.10.202.3 Lame nameserver
200.16.97.17 Lame nameserver
130.59.211.10 Lame nameserver
137.39.1.3 Lame nameserver
168.101.16.10 Lame nameserver
200.16.98.2 Does not respond
skip Mismatched glue Skip comparing the glue provided by the parent servers and that provided by your authoritative DNS servers, as root servers do not provide glue
pass No NS A records at nameservers OK. Your nameservers do include corresponding A records when asked for your NS records. This ensures that your DNS servers know the A records corresponding to all your NS records.
fail All nameservers report identical NS records ERROR. The NS records at all your nameservers are different, check the info above for details.
fail All nameservers respond ERROR: some nameservers does not respond
athea.ar. [200.16.98.2] does not respond
pass Nameserver name validity OK. All of the NS records that your nameservers report seem valid (no IPs or partial domain names).
pass Number of nameservers OK. You have 6 nameservers. You must have at least 2 nameservers (RFC2182 section 5 recommends at least 3 nameservers), and preferably no more than 7.
fail Lame nameservers ERROR: lame nameservers:
ns1.retina.ar. [200.10.202.3]
ctina.ar. [200.16.97.17]
merapi.switch.ch. [130.59.211.10]
ns.UU.NET. [137.39.1.3]
relay1.mecon.gov.ar. [168.101.16.10]
pass Missing (stealth) nameservers OK. All 2 of your nameservers (as reported by your nameservers) are also listed at the parent servers.
pass Missing nameservers 2 OK. All of the nameservers listed at the parent nameservers are also listed as NS records at your nameservers.
pass Nameservers on separate class C's Your nameservers seems to be in different networks.
pass All NS IPs public OK. All of your NS records appear to use public IPs. If there were any private IPs, they would not be reachable, causing DNS delays.
SOA info SOA record Your SOA record is:
Primary nameserver:
Hostmaster E-mail address:
Serial #:
Refresh:
Retry:
Expire:
Default TTL:
pass NS agreement on SOA Serial # OK. All your nameservers agree that your SOA serial number is . That means that all your nameservers are using the same data.
fail SOA MNAME Check ERROR: Your SOA (Start of Authority) record states that your master (primary) name server is: That server is not listed at the parent servers, which is not correct.
warn SOA Serial Number Your SOA serial number is: . This not appears to be in the recommended format of YYYYMMDDnn, where 'nn' is the revision. This number must be incremented every time you make a DNS change.
warn SOA REFRESH value Your SOA REFRESH interval is : seconds. This seems too small (about 3600-7200 seconds is good if not using DNS NOTIFY; RFC1912 2.2 recommends a value between 1200 to 43200 seconds (20 minutes to 12 hours)). This value determines how often secondary/slave nameservers check with the master for updates.
warn SOA RETRY value Your SOA RETRY interval is : seconds. This seems too small (about 120-7200 seconds is good). The retry value is the amount of time your secondary/slave nameservers will wait to contact the master nameserver again if the last attempt failed.
warn SOA EXPIRE value Your SOA EXPIRE time is : seconds. This seems too small (about 1209600 to 2419200 seconds (2-4 weeks) is good). RFC1912 suggests 2-4 weeks. This is how long a secondary/slave nameserver will wait before considering its DNS data stale if it can't reach the primary nameserver.
warn SOA MINIMUM TTL value Your SOA MINIMUM TTL is : seconds. This seems too small (about 3,600 to 86400 seconds or 1-24 hours is good). RFC2308 suggests a value of 1-3 hours. This value used to determine the default (technically, minimum) TTL (time-to-live) for DNS entries, but now is used for negative caching.
I dont know why this is hapenning, this is not my info.
Rh firewall rules make iptables ruls that block port 53.
See iptables -L to edit this.
