I updated custom build and now named won't start.
Any help or feedback would be appreciative. Not seeing any obvious errors in that. I've also changed zero settings, so what's there is from DirectAdmin / server directly.
[root@royal2 ~]# journalctl -xeu named
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone jigging.ca/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone namekus.ca/IN: loaded serial 1
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone taliahlyons.ca/IN: loaded serial 1
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone y4y.ca/IN: loaded serial 1
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone trl.ca/IN: loaded serial 1
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone comprehensiveconsulting.ca/IN: loaded serial 1
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone nikostreats.com/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone justsharing.live/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: /var/named/agg.com.sg.db:27: TTL set to prior TTL (3600)
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: /var/named/agg.com.sg.db:42: TTL set to prior TTL (3600)
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone agg.com.sg/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone motorbiketoursvietnam.org/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone fvmcs.com/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone mariobernabeu.com/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone prplh.art/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone 002434.xyz/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone davisguophotos.com/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone estores.cc/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone vyg.es/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone 6k.si/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone finetradinginc.com/IN: loaded serial 2023022208
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone jonrick.com/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone justgodandgrit.com/IN: loaded serial 2023022207
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone ebullardcounseling.com/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone efiction.org/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone tzak.gr/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone perhour.gr/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone megacow.org/IN: loaded serial 2023022213
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone mbconsulting.biz/IN: loaded serial 2023022213
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone kebrent.com/IN: loaded serial 2023022213
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone precise-hvac.com/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone playingpirates.com/IN: loaded serial 2023022225
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone sandyjuker.com/IN: loaded serial 2023022201
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone kauppinen.org/IN: loaded serial 2023022200
Feb 22 17:15:24 royal2.doroyal.com bash[15402]: zone longevitylifeinsurer.com/IN: loaded serial 2023022205
Feb 22 17:15:24 royal2.doroyal.com systemd[1]: named.service: Control process exited, code=exited status=1
Feb 22 17:15:24 royal2.doroyal.com systemd[1]: named.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: https://access.redhat.com/support
-- The unit named.service has entered the 'failed' state with result 'exit-code'.
Feb 22 17:15:24 royal2.doroyal.com systemd[1]: Failed to start Berkeley Internet Name Domain (DNS).
-- Subject: Unit named.service has failed
-- Unit named.service has failed.
-- The result is failed.
