Need help deploying my Laravel application
Z4Teen
Hello. Im a student new to web hosting and wondering if anyone can help me to host my website using the directadmin control panel because i literally have no idea whats going on and how to do anything. i tried watching some tutorial but even after uploading my files when i typed in my domain name this page appear.
This Site Is Under Construction and Coming Soon.
This site is currently under construction. Please check back at a later time.
Hope anyone could help. i have next to zero knowledge in web hosting. thanks
Laravel expects a different folder structure than the one that DirectAdmin creates.
In DirectAdmin delete the "public_html" folder and then create a symbolic link from "laravel/public" to "public_html".
Wil
Wil
Hello Wil. Thanks for replying.
What is this symbolic link and how do i create it?
What is this symbolic link, and how do I create it?
This feature is called symlink
Laravel framework uses another directory for the public path is a public directory another directories from project cannot be public inside the public_html directory
Yes, the problem here is that this falls outside of DirectAdmin and that you need to have shell access.
Plus know a little bit about how Linux works..
Here's an example of how the public_html folder was set up for a customer of mine that uses Laravel:
Bash:
$ ln -s laravel/public public_html
admin@admin:~/domains/domain.ltd$ ls -alh
total 144K
drwx--x--x  7 admin admin  4.0K Aug 10 18:37 .
drwxr-x---  9 admin access 4.0K Aug  9 23:33 ..
drwxr-xr-x  2 admin admin  4.0K Jul 27 17:49 .htpasswd
-rw-r--r--  1 admin admin  113K Jul 27 17:49 index.html
drwxr-xr-x 13 admin admin  4.0K Aug 10 11:46 laravel
drwx------  2 admin admin  4.0K Aug 10 00:10 logs
lrwxrwxrwx  1 admin admin    13 Jul 27 17:49 private_html -> ./public_html
drwx--x--x  3 admin admin  4.0K Jul 27 17:49 public_ftp
lrwxrwxrwx  1 admin admin    14 Aug 10 18:37 public_html -> laravel/public
drwxr-xr-x  2 admin admin  4.0K Aug  1 00:10 stats
Login via SSH.
Install composer.
go to your public_html
cd /home/username/domains/your.domain/public_html
Install a project
composer create-project laravel/laravel:^8.0 example-app
cd example-app
php artisan serve
And change your htaccess so your domain will go directly to your laravel folder.
