need help! php does not work!
lemberg
after creating account
I put file, named rest.php(permissions 755)
into folder public_html(permissions 750)
Content of file rest.php:
<?php
phpinfo();
Then I click on the name of this file in File Manager and it's empty.
What is wrong I do?
File manager viewing is only usable for HTML files! So when clicking on it, it sees it as 1 HTML tag:
<?php phpinfo(); ?>
Get it ? So you should check this with: http://domain.ext/test.php
If the domain isn't setup yet: http://[server ip]/~[username]/test.php
It should work then! It's a filemanager and doesn't parse PHP files ;)
