You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Need help re-installing proftpd
Running CentOS 5.5 64-Bit with the latest version of DA.
Looks like my proftpd service is stopped. When I click Restart in DA, it says it cannot find the script at /etc/init.d/proftpd
I tried to rebuild proftpd, but it produces an error:
[root@server ~]# cd /usr/local/directadmin/scripts
[root@server scripts]# ./proftpd.sh
Stopping xinetd: [ OK ]
Starting xinetd: [ OK ]
Preparing... ########################################### [100%]
1:proftpd ########################################### [100%]
1:proftpd-standalone ########################################### [100%]
mkdir: cannot create directory `/var/log/proftpd': File exists
How can I resolve this?
Thanks.
When I tried rebuilding proftpd, it also ends with an error:
[root@server custombuild]# ./build clean
[root@server custombuild]# ./build proftpd
File already exists: proftpd-1.3.4a.tar.gz
MD5 Checksum on proftpd-1.3.4a.tar.gz passed.
File already exists: proftpd_freebsd
File already exists: proftpd_debian
Found /usr/local/directadmin/custombuild/proftpd-1.3.4a.tar.gz
Extracting /usr/local/directadmin/custombuild/proftpd-1.3.4a.tar.gz...
Configuring proftpd-1.3.4a...
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 98304
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking whether the C compiler accepts -Wall... yes
checking for getopt... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for getopt_long... yes
checking which extension is used for runtime loadable modules... .so
checking which variable specifies run-time module search path... LD_LIBRARY_PATH
checking for the default library search path... /lib /usr/lib /usr/local/lib
checking for library containing dlopen... -ldl
checking for dlerror... yes
checking for shl_load... (cached) no
checking for shl_load in -ldld... (cached) no
checking for dld_link in -ldld... no
checking for _ prefix in compiled symbols... no
checking whether deplibs are loaded by dlopen... yes
checking for argz.h... yes
checking for error_t... yes
checking for argz_add... yes
checking for argz_append... yes
checking for argz_count... yes
checking for argz_create_sep... yes
checking for argz_insert... yes
checking for argz_next... yes
checking for argz_stringify... yes
checking if argz actually works... yes
checking whether libtool supports -dlopen/-dlpreopen... yes
checking for bindtextdomain in -lintl... no
checking for bindtextdomain in -lc... yes
checking for iconv_open in -liconv... yes
checking for standalone crypt... no
checking for crypt in -lcrypt... yes
checking for standalone gethostbyname... yes
checking for standalone inet_aton... yes
checking for standalone nsl functions... yes
checking for standalone socket functions... yes
checking for _pw_stayopen variable... no
checking krb.h usability... no
checking krb.h presence... no
checking for krb.h... no
checking login.h usability... no
checking login.h presence... no
checking for login.h... no
checking prot.h usability... no
checking prot.h presence... no
checking for prot.h... no
checking usersec.h usability... no
checking usersec.h presence... no
checking for usersec.h... no
checking hpsecurity.h usability... no
checking hpsecurity.h presence... no
checking for hpsecurity.h... no
checking for hpsecurity.h workaround... no
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking junistd.h usability... no
checking junistd.h presence... no
checking for junistd.h... no
checking for memory.h... (cached) yes
checking shadow.h usability... yes
checking shadow.h presence... yes
checking for shadow.h... yes
checking for struct spwd.sp_warn... yes
checking for struct spwd.sp_inact... yes
checking for struct spwd.sp_expire... yes
checking linux/capability.h usability... yes
checking linux/capability.h presence... yes
checking for linux/capability.h... yes
checking for cap_init in -lcap2... no
checking for cap_init in -lcap... no
checking whether to enable mod_cap... yes
checking bstring.h usability... no
checking bstring.h presence... no
checking for bstring.h... no
checking crypt.h usability... yes
checking crypt.h presence... yes
checking for crypt.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for inttypes.h... (cached) yes
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking stropts.h usability... yes
checking stropts.h presence... yes
checking for stropts.h... yes
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for sys/types.h... (cached) yes
checking sys/ucred.h usability... no
checking sys/ucred.h presence... no
checking for sys/ucred.h... no
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking for sys/uio.h... yes
checking for sys/param.h... yes
checking for sys/mount.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking whether netdb.h requires _USE_IRS... no
checking for netinet/in_systm.h... yes
checking for netinet/ip.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for sys/stat.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/termios.h usability... yes
checking sys/termios.h presence... yes
checking for sys/termios.h... yes
checking sys/termio.h usability... no
checking sys/termio.h presence... no
checking for sys/termio.h... no
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking ndir.h usability... no
checking ndir.h presence... no
checking for ndir.h... no
checking sys/ndir.h usability... no
checking sys/ndir.h presence... no
checking for sys/ndir.h... no
checking sys/dir.h usability... yes
checking sys/dir.h presence... yes
checking for sys/dir.h... yes
checking vmsdir.h usability... no
checking vmsdir.h presence... no
checking for vmsdir.h... no
checking ucred.h usability... no
checking ucred.h presence... no
checking for ucred.h... no
checking ucontext.h usability... yes
checking ucontext.h presence... yes
checking for ucontext.h... yes
checking utime.h usability... yes
checking utime.h presence... yes
checking for utime.h... yes
checking utmpx.h usability... yes
checking utmpx.h presence... yes
checking for utmpx.h... yes
checking regex.h usability... yes
checking regex.h presence... yes
checking for regex.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking curses.h usability... no
checking curses.h presence... no
checking for curses.h... no
checking ncurses.h usability... no
checking ncurses.h presence... no
checking for ncurses.h... no
checking for tzname global variable... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for uid_t in sys/types.h... yes
checking for pid_t... yes
checking for size_t... yes
checking for mode_t... yes
checking for off_t... yes
checking type of array argument to getgroups... gid_t
checking for timer_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for short... yes
checking size of short... 2
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 8
checking for long long... yes
checking size of long long... 8
checking for off_t... (cached) yes
checking size of off_t... 8
checking for size_t... (cached) yes
checking size of size_t... 8
checking for time_t... yes
checking size of time_t... 8
checking for char *... yes
checking size of char *... 8
checking for void *... yes
checking size of void *... 8
checking for mode_t... (cached) yes
checking for ino_t... yes
checking for intptr_t... yes
checking for socklen_t... yes
checking utmp.h usability... yes
checking utmp.h presence... yes
checking for utmp.h... yes
checking whether struct utmp has ut_user... yes
checking whether struct utmp has ut_host... yes
checking whether struct utmp has ut_exit... yes
checking whether syslog.h defines LOG_CRON... yes
checking whether syslog.h defines LOG_FTP... yes
checking for d_fd in DIR structure... no
checking for dd_fd in DIR structure... no
checking for __dd_fd in DIR structure... no
checking for working alloca.h... yes
checking for alloca... yes
checking for alloca in -lucb... no
checking whether gcc needs -traditional... no
checking return type of signal handlers... void
checking for vprintf... yes
checking for _doprnt... no
checking for bcopy... yes
checking for crypt... yes
checking for fdatasync... yes
checking for fgetgrent... yes
checking for fgetpwent... yes
checking for fgetspent... yes
checking for flock... yes
checking for fpathconf... yes
checking for freeaddrinfo... yes
checking for futimes... yes
checking for getpgid... yes
checking for getpgrp... yes
checking for nl_langinfo... yes
checking for gai_strerror... yes
checking for iconv... yes
checking for dirfd... yes
checking for getaddrinfo... yes
checking for getcwd... yes
checking for getenv... yes
checking for getgrouplist... yes
checking for getgrset... no
checking for gethostbyname2... yes
checking for gethostname... yes
checking for getnameinfo... yes
checking for gettimeofday... yes
checking for hstrerror... yes
checking for inet_aton... yes
checking for inet_ntop... yes
checking for inet_pton... yes
checking for loginrestrictions... no
checking for memcpy... yes
checking for mempcpy... yes
checking for mkdir... yes
checking for mkstemp... yes
checking for mlock... yes
checking for mlockall... yes
checking for munlock... yes
checking for munlockall... yes
checking for pathconf... yes
checking for putenv... yes
checking for regcomp... yes
checking for rmdir... yes
checking for select... yes
checking for setgroups... yes
checking for socket... yes
checking for statfs... yes
checking for strchr... yes
checking for strcoll... yes
checking for strerror... yes
checking for strsep... yes
checking for strtod... yes
checking for strtof... yes
checking for strtol... yes
checking for strtoull... yes
checking for setprotoent... yes
checking for setspent... yes
checking for endprotoent... yes
checking for vsnprintf... yes
checking for snprintf... yes
checking for setsid... yes
checking for setgroupent... no
checking for seteuid... yes
checking for setegid... yes
checking for setenv... yes
checking for setpgid... yes
checking for siginterrupt... yes
checking for tzset... yes
checking for uname... yes
checking for unsetenv... yes
checking for setpassent... no
checking for struct cmsgcred.cmcred_uid... no
checking for struct sockcred.sc_uid... no
checking for struct sockaddr_in.sin_len... no
checking whether struct addrinfo is defined... yes
checking whether struct sockaddr_storage is defined... yes
checking whether ss_family is defined... yes
checking whether ss_len is defined... no
checking whether __ss_len is defined... no
checking sys/acl.h usability... no
checking sys/acl.h presence... no
checking for sys/acl.h... no
checking acl/libacl.h usability... no
checking acl/libacl.h presence... no
checking for acl/libacl.h... no
checking which POSIX ACL implementation to use... none
checking which sendfile() implementation to use... Linux
checking sys/sendfile.h usability... yes
checking sys/sendfile.h presence... yes
checking for sys/sendfile.h... yes
checking whether setgrent returns void... yes
checking for setproctitle... no
checking libutil.h usability... no
checking libutil.h presence... no
checking for libutil.h... no
checking for setproctitle in -lutil... no
checking sys/pstat.h usability... no
checking sys/pstat.h presence... no
checking for sys/pstat.h... no
checking whether __progname and __progname_full are available... yes
checking which argv replacement method to use... writeable
checking whether printf supports %llu format... yes
checking for duplicate module build requests... no
checking whether OpenSSL is compiled with FIPS support... yes
checking whether linking with OpenSSL functions succeeds... no
checking whether linking with OpenSSL functions requires -ldl... yes
checking whether linking with OpenSSL functions requires -lz... no
configure: creating ./config.status
config.status: creating contrib/Makefile
config.status: creating include/Makefile
config.status: creating lib/Makefile
config.status: creating locale/Makefile
config.status: creating modules/Makefile
config.status: creating src/Makefile
config.status: creating src/prxs
config.status: creating src/ftpdctl.8
config.status: creating src/proftpd.8
config.status: creating src/xferlog.5
config.status: creating tests/Makefile
config.status: creating utils/Makefile
config.status: creating utils/ftpcount.1
config.status: creating utils/ftpscrub.8
config.status: creating utils/ftpshut.8
config.status: creating utils/ftptop.1
config.status: creating utils/ftpwho.1
config.status: creating Makefile
config.status: creating Make.rules
config.status: creating config.h
config.status: executing libtool commands
config.status: executing default commands
Done. Making proftpd-1.3.4a...
Trying to make ProFTPD...
echo \#define BUILD_STAMP \"`date +"%a %b %e %Y %H:%M:%S %Z"`\" > include/buildstamp.h
cd lib/ && make lib
cd src/ && make src
cd modules/ && make static
test -z "1" || (cd locale/ && make locale)
cd utils/ && make utils
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/lib'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c pr_fnmatch.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c sstrncpy.c
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/lib/libcap'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c strsep.c
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/locale'
if [ ! -f bg_BG.po ]; then \
msginit --no-translator -i proftpd.pot -o bg_BG.po -l bg_BG; \
fi
if [ ! -f en_US.po ]; then \
msginit --no-translator -i proftpd.pot -o en_US.po -l en_US; \
fi
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c vsnprintf.c
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/utils'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ftpcount.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c glibc-glob.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c scoreboard.c
if [ ! -f fr_FR.po ]; then \
msginit --no-translator -i proftpd.pot -o fr_FR.po -l fr_FR; \
fi
=> making cap_names.c from <linux/capability.h>
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c glibc-hstrerror.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c misc.c
if [ ! -f it_IT.po ]; then \
msginit --no-translator -i proftpd.pot -o it_IT.po -l it_IT; \
fi
if [ -f bg_BG.po -a ! -f bg_BG.mo ]; then \
msgfmt -o bg_BG.mo bg_BG.po; \
fi
if [ -f en_US.po -a ! -f en_US.mo ]; then \
msgfmt -o en_US.mo en_US.po; \
fi
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/modules'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_core.c
if [ -f fr_FR.po -a ! -f fr_FR.mo ]; then \
msgfmt -o fr_FR.mo fr_FR.po; \
fi
/bin/sh: line 1: msgfmt: command not found
gcc -O2 -Wall -L/lib _makenames.c -o _makenames
if [ -f it_IT.po -a ! -f it_IT.mo ]; then \
msgfmt -o it_IT.mo it_IT.po; \
fi
make[1]: [bg_BG] Error 127 (ignored)
make[1]: [en_US] Error 127 (ignored)
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_xfer.c
make[1]: [fr_FR] Error 127 (ignored)
make[1]: [it_IT] Error 127 (ignored)
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ftpscrub.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c glibc-mkstemp.c
if [ ! -f ja_JP.po ]; then \
msginit --no-translator -i proftpd.pot -o ja_JP.po -l ja_JP; \
fi
if [ -f ja_JP.po -a ! -f ja_JP.mo ]; then \
msgfmt -o ja_JP.mo ja_JP.po; \
fi
make[1]: [ja_JP] Error 127 (ignored)
if [ ! -f ko_KR.po ]; then \
msginit --no-translator -i proftpd.pot -o ko_KR.po -l ko_KR; \
fi
if [ -f ko_KR.po -a ! -f ko_KR.mo ]; then \
msgfmt -o ko_KR.mo ko_KR.po; \
fi
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/src'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c main.c
make[1]: [ko_KR] Error 127 (ignored)
if [ ! -f ru_RU.po ]; then \
msginit --no-translator -i proftpd.pot -o ru_RU.po -l ru_RU; \
fi
if [ -f ru_RU.po -a ! -f ru_RU.mo ]; then \
msgfmt -o ru_RU.mo ru_RU.po; \
fi
make[1]: [ru_RU] Error 127 (ignored)
if [ ! -f zh_CN.po ]; then \
msginit --no-translator -i proftpd.pot -o zh_CN.po -l zh_CN; \
fi
if [ -f zh_CN.po -a ! -f zh_CN.mo ]; then \
msgfmt -o zh_CN.mo zh_CN.po; \
fi
make[1]: [zh_CN] Error 127 (ignored)
if [ ! -f zh_TW.po ]; then \
msginit --no-translator -i proftpd.pot -o zh_TW.po -l zh_TW; \
fi
if [ -f zh_TW.po -a ! -f zh_TW.mo ]; then \
msgfmt -o zh_TW.mo zh_TW.po; \
fi
make[1]: [zh_TW] Error 127 (ignored)
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/locale'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ftpshut.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ftptop.c
./_makenames > cap_names.h
gcc -O2 -Wall -c cap_alloc.c -o cap_alloc.o
gcc -O2 -Wall -c cap_proc.c -o cap_proc.o
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ftpwho.c
gcc -O2 -Wall -c cap_extint.c -o cap_extint.o
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_auth_unix.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_auth_file.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c timers.c
gcc -O2 -Wall -c cap_flag.c -o cap_flag.o
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c sets.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c pool.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c privs.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c str.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c pr-syslog.c
gcc -O2 -Wall -c cap_text.c -o cap_text.o
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c pwgrent.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c tpl.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c table.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c regexp.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_auth.c
gcc -O2 -Wall -c cap_sys.c -o cap_sys.o
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_ls.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_log.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_site.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_delay.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_facts.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c dirtree.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_ident.c
ar rcu libcap.a cap_alloc.o cap_proc.o cap_extint.o cap_flag.o cap_text.o cap_sys.o
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/lib/libcap'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_ratio.c
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/utils'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_readme.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c expr.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_tls.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c support.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_cap.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c netaddr.c
mod_tls.c:381: warning: suggest parentheses around arithmetic in operand of |
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mod_lang.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c inet.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c child.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c parser.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c log.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c lastlog.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c xferlog.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c bindings.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c netacl.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c class.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c help.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c feat.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c netio.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c cmd.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c response.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c data.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c modules.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c stash.c
ar rc libsupp.a pr_fnmatch.o sstrncpy.o strsep.o vsnprintf.o glibc-glob.o glibc-hstrerror.o glibc-mkstemp.o pr-syslog.o pwgrent.o tpl.o
ranlib libsupp.a
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/lib'
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c display.c
gcc -L./lib -o ftpcount utils/ftpcount.o utils/scoreboard.o utils/misc.o -lsupp -lcrypt -ldl -liconv -ldl
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c auth.c
gcc -L./lib -o ftpscrub utils/ftpscrub.o utils/scoreboard.o utils/misc.o -lsupp -lcrypt -ldl -liconv -ldl
gcc -L./lib -o ftpshut utils/ftpshut.o -lsupp -lcrypt -ldl -liconv -ldl
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c fsio.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c mkhome.c
gcc -L./lib -o ftptop utils/ftptop.o utils/scoreboard.o utils/misc.o -lsupp -lcrypt -ldl -liconv -ldl
gcc -L./lib -o ftpwho utils/ftpwho.o utils/scoreboard.o utils/misc.o -lsupp -lcrypt -ldl -liconv -ldl
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ctrls.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c event.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c var.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c throttle.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c session.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c trace.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c encode.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c proctitle.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c filter.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c pidfile.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c env.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c version.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c wtmp.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c memcache.c
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c ftpdctl.c
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/src'
gcc -L./lib -o ftpdctl src/ftpdctl.o src/pool.o src/str.o src/netaddr.o src/log.o src/ctrls.o -lsupp -lcrypt -ldl -liconv -ldl -lssl -lcrypto -L./lib/libcap -lcap -lssl -lcrypto
srcdir=. ./glue.sh mod_core.o mod_xfer.o mod_auth_unix.o mod_auth_file.o mod_auth.o mod_ls.o mod_log.o mod_site.o mod_delay.o mod_facts.o mod_ident.o mod_ratio.o mod_readme.o mod_tls.o mod_cap.o mod_lang.o
gcc -DHAVE_CONFIG_H -DLINUX -I.. -I../include -O2 -Wall -c module_glue.c
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/modules'
test -z """" -a -z """" || (cd modules/ && make shared)
test -f ./module-libs.txt || touch ./module-libs.txt
/bin/sh ./libtool --mode=link --tag=CC gcc -L./lib -o proftpd src/main.o src/timers.o src/sets.o src/pool.o src/privs.o src/str.o src/table.o src/regexp.o src/dirtree.o src/expr.o src/support.o src/netaddr.o src/inet.o src/child.o src/parser.o src/log.o src/lastlog.o src/xferlog.o src/bindings.o src/netacl.o src/class.o src/scoreboard.o src/help.o src/feat.o src/netio.o src/cmd.o src/response.o src/data.o src/modules.o src/stash.o src/display.o src/auth.o src/fsio.o src/mkhome.o src/ctrls.o src/event.o src/var.o src/throttle.o src/session.o src/trace.o src/encode.o src/proctitle.o src/filter.o src/pidfile.o src/env.o src/version.o src/wtmp.o src/memcache.o modules/mod_core.o modules/mod_xfer.o modules/mod_auth_unix.o modules/mod_auth_file.o modules/mod_auth.o modules/mod_ls.o modules/mod_log.o modules/mod_site.o modules/mod_delay.o modules/mod_facts.o modules/mod_ident.o modules/mod_tls.o modules/mod_readme.o modules/mod_ratio.o modules/mod_cap.o modules/mod_lang.o modules/module_glue.o -lsupp -lcrypt -ldl -liconv -ldl -lssl -lcrypto -L./lib/libcap -lcap -lssl -lcrypto `uniq ./module-libs.txt | tr '\n' ' '`
libtool: link: gcc -o proftpd src/main.o src/timers.o src/sets.o src/pool.o src/privs.o src/str.o src/table.o src/regexp.o src/dirtree.o src/expr.o src/support.o src/netaddr.o src/inet.o src/child.o src/parser.o src/log.o src/lastlog.o src/xferlog.o src/bindings.o src/netacl.o src/class.o src/scoreboard.o src/help.o src/feat.o src/netio.o src/cmd.o src/response.o src/data.o src/modules.o src/stash.o src/display.o src/auth.o src/fsio.o src/mkhome.o src/ctrls.o src/event.o src/var.o src/throttle.o src/session.o src/trace.o src/encode.o src/proctitle.o src/filter.o src/pidfile.o src/env.o src/version.o src/wtmp.o src/memcache.o modules/mod_core.o modules/mod_xfer.o modules/mod_auth_unix.o modules/mod_auth_file.o modules/mod_auth.o modules/mod_ls.o modules/mod_log.o modules/mod_site.o modules/mod_delay.o modules/mod_facts.o modules/mod_ident.o modules/mod_tls.o modules/mod_readme.o modules/mod_ratio.o modules/mod_cap.o modules/mod_lang.o modules/module_glue.o -L/usr/local/directadmin/custombuild/proftpd-1.3.4a/lib -lsupp -lcrypt /usr/local/lib/libiconv.so -ldl -L/usr/local/directadmin/custombuild/proftpd-1.3.4a/lib/libcap -lcap -lssl -lcrypto
Make complete
Installing proftpd-1.3.4a...
cd lib/ && make lib
make[1]: Nothing to be done for `lib'.
cd src/ && make src
make[1]: Nothing to be done for `src'.
make[1]: Nothing to be done for `all'.
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
make[1]: Nothing to be done for `utils'.
/usr/bin/install -c -s -o ftp -g ftp -m 0755 proftpd /usr/sbin/proftpd
if [ -f /usr/sbin/in.proftpd ] ; then \
rm -f /usr/sbin/in.proftpd ; \
fi
ln -s proftpd /usr/sbin/in.proftpd
chown -h ftp:ftp /usr/sbin/in.proftpd
test -z """" -a -z """" -a -z """" || (cd modules/ && make install)
cd contrib/ && make install-utils
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/contrib'
/usr/bin/install -c -o ftp -g ftp -m 0755 ftpasswd /usr/bin/ftpasswd
/usr/bin/install -c -o ftp -g ftp -m 0755 ftpmail /usr/bin/ftpmail
/usr/bin/install -c -o ftp -g ftp -m 0755 ftpquota /usr/bin/ftpquota
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/contrib'
/usr/bin/install -c -s -o ftp -g ftp -m 0755 ftpcount /usr/bin/ftpcount
/usr/bin/install -c -s -o ftp -g ftp -m 0755 ftpdctl /usr/bin/ftpdctl
/usr/bin/install -c -s -o ftp -g ftp -m 0755 ftpscrub /usr/sbin/ftpscrub
/usr/bin/install -c -s -o ftp -g ftp -m 0755 ftpshut /usr/sbin/ftpshut
/usr/bin/install -c -s -o ftp -g ftp -m 0755 ftptop /usr/bin/ftptop
/usr/bin/install -c -s -o ftp -g ftp -m 0755 ftpwho /usr/bin/ftpwho
/usr/bin/install -c -o ftp -g ftp -m 0755 src/prxs /usr/bin/prxs
if [ ! -f /etc/proftpd.conf ] ; then \
/usr/bin/install -c -o ftp -g ftp -m 0644 \
./sample-configurations/basic.conf \
/etc/proftpd.conf ; \
fi
/usr/bin/install -c -o ftp -g ftp -m 0644 ./src/ftpdctl.8 /usr/share/man/man8
/usr/bin/install -c -o ftp -g ftp -m 0644 ./src/proftpd.8 /usr/share/man/man8
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpasswd.1 /usr/share/man/man1
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpmail.1 /usr/share/man/man1
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpquota.1 /usr/share/man/man1
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpscrub.8 /usr/share/man/man8
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpshut.8 /usr/share/man/man8
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpcount.1 /usr/share/man/man1
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftptop.1 /usr/share/man/man1
/usr/bin/install -c -o ftp -g ftp -m 0644 ./utils/ftpwho.1 /usr/share/man/man1
/usr/bin/install -c -o ftp -g ftp -m 0644 ./src/xferlog.5 /usr/share/man/man5
cd lib/ && make install
make[1]: Nothing to be done for `install'.
/usr/bin/install -c -o ftp -g ftp -m 0644 config.h /usr/include/proftpd/config.h
cd include/ && make install
make[1]: Entering directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/include'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/proftpd-1.3.4a/include'
/usr/bin/install -c -o ftp -g ftp -m 0644 proftpd.pc /usr/lib/pkgconfig/proftpd.pc
test -z "1" || (cd locale/ && make install)
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
for lang in bg_BG en_US fr_FR it_IT ja_JP ko_KR ru_RU zh_CN zh_TW ; do \
if [ -f $lang.mo ]; then \
if [ ! -d /usr/share/locale/$lang/LC_MESSAGES ]; then \
mkdir -p /usr/share/locale/$lang/LC_MESSAGES; \
chown ftp:ftp /usr/share/locale/$lang/LC_MESSAGES; \
chmod 0755 /usr/share/locale/$lang/LC_MESSAGES; \
fi; \
/usr/bin/install -c -o ftp -g ftp -m 0644 $lang.mo /usr/share/locale/$lang/LC_MESSAGES/proftpd.mo; \
fi; \
done
Done proftpd.
pure-ftpd: no process killed
Restarting ProFTPd.
Shutting down proftpd: [FAILED]
Starting proftpd: server.pnwfx.com proftpd[30214]: Fatal: Group: Unknown group 'nogroup' on line 27 of '/etc/proftpd.conf'
[FAILED]
delete proftpd.conf (or backup it) and rebuild, seems that conf is messed up.
Regards
I tried that and it produced the same error when I tried rebuilding it.
Should I run "yum remove proftpd" to have yum remove it and then try rebuilding it again with DA?
For sure you dont have to use yum for instlal proftpd, yes, remove using yum and reinstall it using custombuild.
Regards
I removed it via yum and tried again, another error at the end:
[root@server ~]# yum remove proftpd
Loaded plugins: fastestmirror
Setting up Remove Process
Resolving Dependencies
--> Running transaction check
---> Package proftpd.x86_64 0:1.3.1-1 set to be erased
--> Processing Dependency: proftpd for package: proftpd-standalone
---> Package proftpd-standalone.x86_64 0:1.3.1-1 set to be erased
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Removing:
proftpd x86_64 1.3.1-1 installed 5.1 M
Removing for dependencies:
proftpd-standalone x86_64 1.3.1-1 installed 232 k
Transaction Summary
Remove 2 Package(s)
Reinstall 0 Package(s)
Downgrade 0 Package(s)
Is this ok [y/N]: y
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Erasing : proftpd-standalone 1/2
warning: /etc/proftpd.conf saved as /etc/proftpd.conf.rpmsave
Erasing : proftpd 2/2
Removed:
Dependency Removed:
Complete!
[root@server ~]# cd /usr/local/directadmin/custombuild
cp: cannot stat `/etc/proftpd.conf': No such file or directory
cd lib/ && make lib
cd src/ && make src
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
ranlib libsupp.a
Make complete
cd lib/ && make lib
cd src/ && make src
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi
fi; \
fi; \
done
cp: cannot stat `/usr/local/directadmin/custombuild/proftpd_boot': No such file or directory
chmod: cannot access `/etc/init.d/proftpd': No such file or directory
error reading information on service proftpd: No such file or directory
./build: line 8425: [: missing `]'
Done proftpd.
Restarting ProFTPd.
./build: line 8458: /etc/init.d/proftpd: No such file or directory
Fixed the problem.
In /etc/proftpd.conf I changed User and Group both to "ftp" and all went through good.
Thanks.
