Need help with Dns Problems!
sassysue
Hello All I need some help with my server problems i really do not no what's the matter i changed the dns to point to my new server im not Direct Admin and i did this before on cpanel but for some reason i cannot receive emails ect
here's my total dns setup!
etradehosting.com. A 64.85.164.208
ftp A 64.85.164.208
localhost A 127.0.0.1
mail A 64.85.164.208
pop A 64.85.164.208
www A 64.85.164.208
etradehosting.com. NS ns1.etradehosting.com
etradehosting.com. NS ns2.etradehosting.com
mail MX 10
etradehosting.com. TXT "v=spf1 a mx ip4:64.85.164.208 ?all"
For some reason it keeps giving me errors!
Any help will help me to figure this mess i got my self into!
Richard!
Without knowing the real domain name, it may be hard for others to check the problem.
You said the name servers are
but why you have
Domain.com NS ns1.Domain.com
Domain.com NS ns2.Domain.com
Following is your zone record info.
These info are publicly available, so don't worry:
$ORIGIN .
$TTL 14400 ; 4 hours
etradehosting.com IN SOA ns1.etradehosting.com.etradehosting.com. root.etradehosting.com. (
2008040509 ; serial
14400 ; refresh (4 hours)
3600 ; retry (1 hour)
1209600 ; expire (2 weeks)
86400 ; minimum (1 day)
NS ns1.etradehosting.com.etradehosting.com.
NS ns2.etradehosting.com.etradehosting.com.
A 64.85.164.208
MX 10 mail.etradehosting.com.
$ORIGIN etradehosting.com.
ftp A 64.85.164.208
pop A 64.85.164.208
www A 64.85.164.208
You have wrong ns record in your zone file.
it seems you have :
as nameservers in your zone file instead of ns1.etradehosting.com, and ns2.etradehosting.com
when you input the nameserver in directadmin, make sure you have a full stop after the nameserver host name (ie ns1.domain.com. instead of ns1.domin.com) or direadmin will append the domain name to the name you have input)
Another thing I find is one of you name server has no reponse, I think ns1 (the 210 one) have problem. ns2 has response and should be online.
another thing you may need to do is add an A record for both ns1.etradehosting.com and ns2.etradehosting.com to your zone record which point to the ip address of your dns servers. (ie the 209 and 210 server)
Here is the problem i have spot from your dns setting. I may miss something and other forum members may find more...:D
Hey,
Pkilam, how did you obtain the zone record info?
I am having the same problems with my new server and wish to perform this test for myself.
I can see etradehosting.com is up and running using ns1.etradehosting.com and ns2.etradehosting.com
Sassysue, how did you solve your problem?
Thanks,
me.
