I am trying to enable Spamassissin and I have runned the folowing commands
./spam.sh
Then I tried to run the command /usr/bin/spamd -d -c -m 5 but this doesn´t work.
I looked into the install procedure of spam.sh and it says some programms needs to be installed on the server. Can somebody tell me how to solve these thing?
ERROR: the required Digest::SHA1 module is not installed.
The Digest::SHA1 module is used as a cryptographic hash for some
tests and the Bayes subsystem. It is also used by Razor2.
NOTE: the optional Net:
NS (version 0.34) module is not installed.
Used for all DNS-based tests (SBL, XBL, SpamCop, DSBL, etc.),
perform MX checks, and is also used when manually reporting spam to
SpamCop. Recommended.
If this is installed and you are using network tests of any variety
(which is the default), then you need to make sure the Net:
NS
version is sufficiently up-to-date:
- version 0.34 or higher on Unix systems
- version 0.46 or higher on Windows systems
NOTE: the optional Mail::SPF::Query module is not installed.
Used to check DNS Sender Policy Framework (SPF) records to fight email
address forgery and make it easier to identify spams.
NOTE: the optional IP::Country module is not installed.
Used by the RelayCountry plugin (not enabled by default) to determine
the domain country codes of each relay in the path of an email.
NOTE: the optional Razor2 (version 2.61) module is not installed.
Used to check message signatures against Vipul's Razor collaborative
filtering network. Razor has a large number of dependencies on CPAN
modules. Feel free to skip installing it, if this makes you nervous;
SpamAssassin will still work well without it.
More info on installing and using Razor can be found
at http://wiki.apache.org/spamassassin/InstallingRazor .
NOTE: the optional Net::Ident module is not installed.
If you plan to use the --auth-ident option to spamd, you will need
to install this module.
NOTE: the optional IO::Socket::INET6 module is not installed.
This is required if the first nameserver listed in your IP
configuration or /etc/resolv.conf file is available only via
an IPv6 address.
NOTE: the optional Time::HiRes module is not installed.
If this module is installed, the processing times are logged/reported
more precisely in spamd.
NOTE: the optional DBI module is not installed.
If you intend to use SpamAssassin with an SQL database backend for
user configuration data, Bayes storage, or other storage, you will need
to have these installed; both the basic DBI module and the driver for
your database.
NOTE: the optional Archive::Tar module is not installed.
The "sa-update" script requires this module to access tar update
archive files.
NOTE: the optional IO::Zlib module is not installed.
The "sa-update" script requires this module to access compressed
update archive files.
REQUIRED module missing: Digest::SHA1
optional module missing: Net:
NS
optional module missing: Mail::SPF::Query
optional module missing: IP::Country
optional module missing: Razor2
optional module missing: Net::Ident
optional module missing: IO::Socket::INET6
optional module missing: Time::HiRes
optional module missing: DBI
optional module missing: Archive::Tar
optional module missing: IO::Zlib
warning: some functionality may not be available,
please read the above report before continuing!
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
[root@server3 scripts]# /usr/bin/spamd -d -c -m 5
-bash: /usr/bin/spamd: No such file or directory
./spam.sh
an IPv6 address.
your database.
archive files.
