Richard G
I installed Letsencrypt today using this help section:
https://help.directadmin.com/item.php?id=629
From what I read elsewhere on the forums, it seemed I needed to do:
./build rewrite_confs
which I also did and it updated without errors.
Now in the user section of an account, the line "SSL Certificates" appears, which is good.
But it only works with admin user level, when I click on it as another user or reseller, this error appears:
Which is odd, because I understood clients could make their own Letsencrypt certificate without the need of a seperate ip address.
So what did I do wrong or what did I miss?
Cannot Execute Your Request
Details
You can only add a certificate if you own the ip you are using
Info for Admins: Assigning an owned IP
