Note: This issue has now been resolved, see the bottom of the post for how to get it working again.
Hi all,
I saw that the DirectAdmin 1.345 update was released earlier today, so went ahead and clicked update in the control panel.
A minute or two later I get an email titled "New Message: DirectAdmin has been updated" fantastic, or so you would have thought...
I then tried to login to DirectAdmin - connection refused.
SSH'd into the server, checked the active ports - no 2222.
Ok, no problem - service directadmin restart
Hang on a minute, no libssl.so.6? find / -name 'libssl.so.6'
Ok... so it exists, odd.
Figured I'd reboot the server for the first time in 41 days, nope. No good.
I then went and ran a manual update...
When I got to ./directadmin p
Then when I get to ./update.sh
Sure enough, I checked service --status-all
Does anyone have any idea what has happened here? Everything was running absolutely fine before the 1.345 update - all previous updates have been just fine too
any help would be much appreciated.
Server is running CentOS 5.4 64bit.
Solution
Ok... for whatever reason, it turns out that if you're running CentOS 64bit you need to install the following packages:
Why? Goodness only knows. It was working perfectly fine for me before now without them.
Just run:
yum install openssl openssl-devel libstdc++
And make sure exclude=*.i386 *.i586 *.i686 is not in your /etc/yum.conf
Problem solved
Hopefully this will save someone all the time I spent on trying to resolve this issue.
Hi all,
Stopping DirectAdmin: [FAILED]
Starting DirectAdmin: /usr/local/directadmin/directadmin: error while loading shared libraries: libssl.so.6: cannot open shared object file: No such file or directory
[FAILED]
/lib64/libssl.so.6
./directadmin: error while loading shared libraries: libssl.so.6: cannot open shared object file: No such file or directory
Stopping DA-PopB4Smtp: [FAILED]
Starting DA-PopB4Smtp: /usr/local/directadmin/da-popb4smtp: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
[FAILED]
da-popb4smtp dead but subsys locked
directadmin dead but subsys locked
Solution
PHP:
openssl i686 0.9.8e-12.el5
openssl-devel i386 0.9.8e-12.el5
libstdc++ i386 4.1.2-46.el5_4.1
Just run:
Problem solved
