hi all.
There was a problem with installing mpm itk on directadmin.
rebuild apache, error occurred:
but as can be seen, all packages are installed (installed from the. / build directory in directadmin)
how to solve this problem?
or you can remove a package that is installed with directadmin (but how?)
and place
[root @ localhost httpd-2.2.17] #. / buildconf
found apr source: srclib / apr
found apr-util source: srclib / apr-util
rebuilding srclib / apr / configure
buildconf: checking installation ...
buildconf: python version 2.4.3 (ok)
buildconf: autoconf version 2.67 (ok)
buildconf: libtool version 2.4 (ok)
Copying libtool helper files ...
/ libtool.m4 not found
. / buildconf failed for apr
and place
