Ok the timeouts problem maybe only on https and ipv6 related
ikkeben
Netherlands Germany
Here sometimes ofter mentioned in this forum problems slow or kind of hickups.
Now did some testing external , then on ipv6 the https was not found sometimes.
So maybe to look for that and check if something is different.
While these failures are random not often but also nowhere found errors in logs on server. Wen doing the test later then all 100 % ok
Settings for domain , in DA gui forced ssl, private dir and redirect to non www.
EDIT: DNSSEC, and external dns service at a very fast service non cloudflare ;)
Verdict:​
Your web server is unreachable.
Technical details:​
Web server IP addressHTTPS existent
ipv6adresnot reachable
ipv4 adresyes
same test minutes later no changes done:!
Technische details:​
Webserver-IP-adresHTTPS existent
ipv6adresyes
ipv4adresyes
Could this al be related. somehow?
Even that some can't install domains in fresh install
If i do test her all ok but that is only short test https://www.ipv6-test.com/validate.php
If i do test running longer or more connections more same domain open in several browser then problem happens random hang no error ..
As test on internet.nl did go 25 times ok but 3 times error https on ipv6
