open_basedir restriction problem
DA-Rff
open_basedir restriction problem -SOLVED
on one of my sites I suddenly get this message:
Warning: session_start() [function.session-start]: open_basedir restriction in effect. File(/var/tmp/) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php/) in /xxx/xxx/domains/xxx.nl/public_html/manager/includes/config.inc.php on line 60
Fatal error: session_start() [<a href='function.session-start'>function.session-start</a>]: Failed to initialize storage module: files (path: ) in /xxx/xxx/domains/xxx.nl/public_html/manager/includes/config.inc.php on line 60
Line 60 of that file says: session_start();
I have other sites which use same cms on this server that do not have this problem.
thanks for any help.
First, check that session.save_path is set to "/tmp" and not "/var/tmp" in the correct php.ini file. Then, check that the CMS doesn't call session_save_path() with the wrong path.
Hi tillo
phpinfo.php says php.ini in /usr/local/lib
I changed
; session.save_path = /tmp
to
rebooted and phpinfo.php still says for session.save_path no value
Any more ideas?
tillo,
thanks for thinking along, but the cms does not specify the path.
Strange thing is that I have more than one site on this server that uses the same cms, and no problems on any of them.
How can I debug this?
For starters you may want to "grep -Ri session_save_path /home/username/domains/domain.example" for the concerned user and domain. If there is a call like that, check which variable is using and modify it accordingly. If not, try to modify the session.save_path line on every php.ini file in your system ("locate php.ini") and restart gracefully apache.
tillo thanks,
I made one step forward, I managed to set the session.save_path to /tmp
and that seems to sort out most php problems on this domain.
Only the cms now throws a totally blank page...
thanks,
issue fixed by doing reinstall of cms and restoring databases
looks like the cms corrupted itself during saving of changes by the cms.
Oliver
