OpenLiteSpeed Problem
Bipul-HostMight
LiteSpeed not running or not running properly. If i do restart, it is fixing up but the problem is back again and again. last 24 hours i noticed two-three more time.
To diagnosis :
At 1st i have check the Services status from DA UI, and its showing running with many PID 1027 1030 1032 1035 1047 1049 1056 1079 1081 1084 1087 1089 1093 1..
than i have checked by using command :
/usr/local/lsws/bin/lswsctrl status
[ERROR] litespeed is not running.
so i restart and everything up. but the problem is back again
Some of lsrestart.log
Mon Jul 1 12:07:01 UTC 2019
restart, LSWS running: 1
Mon Jul 1 12:28:01 UTC 2019
Tue Jul 2 00:12:01 UTC 2019
Tue Jul 2 02:20:27 UTC 2019
stop, LSWS running: 0
2 13:48:47 UTC 2019
, LSWS running: 0
Server Ram :
free -m
total used free shared buff/cache available
Mem: 1838 874 170 43 793 681
Swap: 0 0 0
Litespeed is not running now , I know this will solved by restart but I'm trying to located the problem.
Thank you for reading the post And i would like to thank DirectAdmin Team.
please note , I request add a sub categories under " Technical Discussion" as OpenLiteSpeed/LiteSpeed
I would suggest that you open a ticket with DirectAdmin support and provide access to your server. Probably they can help you.
Trying to identify reasons on why OpenLiteSpeed crashes will take long time here on the forums.
If you don't own a license, then you might consider hiring somebody for this work.
If hiring somebody for this job is not an option for you then you need to gather as much information as possible, including error logs under /var/log/httpd/ and /usr/local/lsws/logs/ and post them here using CODE tags.
