Hallo!
I have problem with PEAR on my serwer ..
ssh:
sh tan
79:~# which pear
/usr/local/bin/pear
PHP test code :?
Problem.. pear path ?
Warning: require_once(PEAR.php) [function.require-once]: failed to open stream: No such file or directory in /home/esbav17/domains/esbav.org/public_html/a.php on line 5
Fatal error: require_once() [function.require]: Failed opening required 'PEAR.php' (include_path='/usr/local/lib/php/') in /home/esbav17/domains/esbav.org/public_html/a.php on line 5
How do I resolve the problem
Thank you
ssh:
sh tan
79:~# which pear
/usr/local/bin/pear
PHP test code :?
PHP:
<?php
error_reporting(E_ALL);
#ini_set('include_path', '~/pear/lib'.PATH_SEPARATOR.ini_get('include_path'));
set_include_path('/usr/local/lib/php/'); //first test /usr/local/bin/pear
require_once 'PEAR.php';
if(!class_exists('PEAR')) die('PEAR NOT FOUND');
require_once 'DB.php';
require_once 'Cache.php';
require_once 'HTML/Template/Sigma.php';
____
Thank you
