PHP-FPM I/O Monitor Script for DirectAdmin
kalmaarikalmer
Hi, asking for recommendations or improvements to monitor and log user php processes in a shared hosting. This script was made to dump overloading clients with info and possibly have their web developers take a look and fix their issues.
Summary:
This script monitors PHP-FPM processes of a specified user, identifying those with high I/O usage. Once a process surpasses the set I/O threshold, the script employs strace to trace its system calls, capturing the results in a log file. Designed especially for administrators and developers engaged with DirectAdmin, this script offers valuable insights into processes consuming a significant amount of I/O resources.
Features:
  • User-Specific PHP-FPM Monitoring: Tailored monitoring of PHP-FPM processes for a particular user.
  • Child Process Retrieval: Automatically fetches child processes linked to a PHP-FPM process in a recursive manner.
  • Configurable I/O Threshold: Set a custom I/O usage percentage that, when exceeded, activates strace.
  • Resource Management: Imposes a limit on concurrently running strace processes to maintain system performance.
  • Customizable Monitoring Intervals: The interval between I/O checks can be adjusted according to user preference.
  • Robust Error Handling: Incorporated checks ensure required utilities are installed, and specified users exist.
  • Cleanup Mechanism: The script periodically scans for and terminates strace processes that are no longer needed, optimizing resource utilization.
Usage:
Run the script with the following options:
  • --user : Denotes the user whose PHP-FPM processes are to be monitored. (Required)
  • --logpath : Specifies the directory where the tracing logs will be saved. This is a mandatory parameter and must always be provided.
  • --iothreshold : Establish a custom I/O usage threshold (in percentage) that initiates strace. By default, it's set at 50%.
  • --sleep : Dictate the sleep interval in seconds between consecutive checks. It's set to 60 seconds if not defined.
  • --help: Showcases the help message detailing available options.
  • --maxstrace: Limit the number of concurrent strace processes.
Example Usage:
To scrutinize the user 'john', save logs in '/var/logs', set an I/O threshold of 70%, and execute a check every 45 seconds, use:
./script.sh --user john --logpath /var/logs --iothreshold 70 --sleep 45
Dependencies:
To ensure the smooth operation of the script, verify the installation of both iotop and strace utilities on the system.
Note:
For optimal performance, the script might need elevated privileges, especially when accessing tools such as iotop. Make certain to possess the requisite permissions or contemplate running the script via sudo.
Bash:
#!/bin/bash
# Default values
LOG_DIR=""
USERNAME=""
SHOW_HELP=false
IO_THRESHOLD=50
SLEEP_INTERVAL=60
MAX_STRACE=10
# Check for necessary utilities
if ! command -v strace &> /dev/null || ! command -v iotop &> /dev/null; then
    echo "Missing required utilities. Ensure both strace and iotop are installed."
    exit 1
fi
# Parse command line arguments
while [[ $# -gt 0 ]]; do
    key="$1"
    case $key in
        --user)
        USERNAME="$2"
        shift
        shift
        --logpath)
        LOG_DIR="$2"
        shift
        shift
        --iothreshold)
        IO_THRESHOLD="$2"
        shift
        shift
        --sleep)
        SLEEP_INTERVAL="$2"
        shift
        shift
        --maxstrace)
        MAX_STRACE="$2"
        shift
        shift
        --help)
        SHOW_HELP=true
        shift
        echo "Invalid argument: $1"
        echo "Use --help to see available commands."
        exit 1
    esac
done
# Show help and exit
if $SHOW_HELP || [ -z "$USERNAME" ] || [ -z "$LOG_DIR" ]; then
    echo "Usage: ./script.sh --user  --logpath  [--iothreshold ] [--sleep ] [--maxstrace ]"
    echo "  --user       : Specify the username for which to trace php-fpm processes. (Required)"
    echo "  --logpath    : Specify the directory where logs should be stored. (Required)"
    echo "  --iothreshold: Define the I/O usage percentage that triggers strace. Defaults to 50%."
    echo "  --sleep      : Define the sleep interval in seconds between checks. Defaults to 60 seconds."
    echo "  --maxstrace  : Define the maximum number of concurrent strace processes. Defaults to 5."
    echo "  --help       : Display this help message."
    exit 0
fi
# Create log directory if it doesn't exist
mkdir -p $LOG_DIR
get_children() {
    local parent=$1
    for child in $(pgrep -P $parent); do
        echo $child
        get_children $child
    done
while true; do
    # Print a timestamped message for each refresh
    echo "Checking for high I/O php-fpm processes and their children... (Timestamp: $(date))"
    # Get all php-fpm PIDs for specified user
    PHP_FPM_PIDS=$(pgrep -u $USERNAME php-fpm)
    # Accumulate all child PIDs of these php-fpm processes
    ALL_PIDS=""
    for PID in $PHP_FPM_PIDS; do
        ALL_PIDS+="$PID "
        ALL_PIDS+=$(get_children $PID)
        ALL_PIDS+=" "
    done
    # Check I/O for each PID and limit concurrent strace processes
    CURRENT_STRACE_COUNT=0
    for PID in $ALL_PIDS; do
        # Check if the process is using over the specified I/O threshold
        IO_USAGE=$(sudo iotop -b -n 1 -P | awk -v pid=$PID '$1 == pid && $10 > '$IO_THRESHOLD' {print $10}')
        if [[ ! -z $IO_USAGE ]] && [[ $CURRENT_STRACE_COUNT -lt $MAX_STRACE ]]; then
            LOG_FILE="$LOG_DIR/${USERNAME}.log.$PID"
            # Trace the process
            echo "Tracing high I/O PID $PID..."
            strace -p $PID -o $LOG_FILE &
            ((CURRENT_STRACE_COUNT++))
        fi
    done
    # Sleep for a while before checking again
    sleep $SLEEP_INTERVAL
done
