djtamse.eu
- May 31, 2009
so i am trying to install a script with a php install it says it can import database and database was found but when i press finish it doesent import my database and i havet grant privilliges to yes all is set to yes what could cause the problem ?
[Sun May 13 02:08:05 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun May 13 02:08:05 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun May 13 02:08:05 2012] [notice] Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8o DAV/2 PHP/5.2.17 configured -- resuming normal operations
[Sun May 13 02:09:01 2012] [notice] SIGHUP received. Attempting to restart
[Sun May 13 02:09:02 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun May 13 02:09:02 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun May 13 02:09:02 2012] [notice] Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8o DAV/2 PHP/5.2.17 configured -- resuming normal operations
[Sun May 13 02:09:45 2012] [error] [client 95.166.247.112] File does not exist: /var/www/html/favicon.ico
[Sun May 13 02:09:45 2012] [error] [client 95.166.247.112] File does not exist: /var/www/html/404.shtml
[Sun May 13 02:10:02 2012] [notice] caught SIGTERM, shutting down
[Sun May 13 02:10:05 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun May 13 02:10:05 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun May 13 02:10:05 2012] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun May 13 02:10:06 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun May 13 02:10:06 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun May 13 02:10:06 2012] [notice] Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8o DAV/2 PHP/5.2.17 configured -- resuming normal operations
sh: host: command not found
[Sun May 13 11:12:24 2012] [error] [client 180.76.5.63] File does not exist: /var/www/html/robots.txt
[Sun May 13 11:12:24 2012] [error] [client 180.76.5.63] File does not exist: /var/www/html/404.shtml
sh: /usr/bin/mysql: No such file or directory
[Sun May 13 16:07:10 2012] [notice] caught SIGTERM, shutting down
[Sun May 13 16:07:13 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun May 13 16:07:13 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun May 13 16:07:13 2012] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun May 13 16:07:14 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun May 13 16:07:14 2012] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun May 13 16:07:14 2012] [notice] Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8o DAV/2 PHP/5.2.17 configured -- resuming normal operations
sh: mysqldump: command not found
