PHP Post Max Size for selected site
tarta
One of the WordPress sites running on VPS requires setting up PHP Post Max Size to 256M.
Questions:
1) can I set the value for this site only?
2) where can I change beyond 128M limit available in PHP settings:
Regards
You have to manually adjust the php.ini file for that version of php you are running on that site.
Example: /usr/local/php73/lib/php.ini
1) ok, ini updated
post_max_size = 256M
2) php-fpm80 restarted (via DA panel)
3) yet, it still shows me 128M which must be coming from a global override that I need for other settings.
4) should I need set 256M for each ini separately? Is there a way to add 256M value for global drop-downs?
I don't know. I have never used that form. But yes you do have to edit for each version of php.
Where do you find that form, I would have used
User>Account Manager>PHP Settings
I dont think I've ever seen that form before.
create dir if not exist: /usr/local/directadmin/data/templates/custom/
copy /usr/local/directadmin/data/templates/php_settings.json to this dir
modify/extend range for needed parameters
you can also change ranges to list of values:
Example: change range from
"max_input_vars" : {
"default" : 10000,
"type": "int",
"range" : [ 1, 100000 ]
to a list of values:
"default" : 10000,
"type": "list",
"values" : [
"8000",
"12000",
"16000",
"20000",
1) ok, ini updated
Please try to rebuild PHP
da build php
da build rewrite_confs
#note: For php-fpm, that's form is global config for the user.
if you want per-site setting, just create file at your domain site.
#domain.com/public_html/.user.ini
I don't know if you already have setting in that's form, maybe ".user.ini' won't work anymore.
