My host has installed DirectAdmin on an unmanaged VPS.
I have entered phpMyAdmin via DirectAdmin/user level/phpMyAdmin.
Firstly, it shows:
How best to update to the latest version?
Secondly it shows:
When I follow the 'click here' it shows:
Is this something I need to be worried about?
Thank you for any help with this,
Jono.
Firstly, it shows:
A newer version of phpMyAdmin is available and you should consider upgrading. The newest version is 3.4.10.1, released on 2012-02-18.
Secondly it shows:
The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. To find out why click here.
$cfg['Servers'][$i]['pmadb'] ... not OK [ Documentation ]
$cfg['Servers'][$i]['relation'] ... not OK [ Documentation ]
General relation features: Disabled
$cfg['Servers'][$i]['table_info'] ... not OK [ Documentation ]
Display Features: Disabled
$cfg['Servers'][$i]['table_coords'] ... not OK [ Documentation ]
$cfg['Servers'][$i]['pdf_pages'] ... not OK [ Documentation ]
Creation of PDFs: Disabled
$cfg['Servers'][$i]['column_info'] ... not OK [ Documentation ]
Displaying Column Comments: Disabled
Browser transformation: Disabled
$cfg['Servers'][$i]['bookmarktable'] ... not OK [ Documentation ]
Bookmarked SQL query: Disabled
$cfg['Servers'][$i]['history'] ... not OK [ Documentation ]
SQL history: Disabled
$cfg['Servers'][$i]['designer_coords'] ... not OK [ Documentation ]
Designer: Disabled
$cfg['Servers'][$i]['tracking'] ... not OK [ Documentation ]
Tracking: Disabled
$cfg['Servers'][$i]['userconfig'] ... not OK [ Documentation ]
User preferences: Disabled
Quick steps to setup advanced features:
Create the needed tables with the script/create_tables.sql. Documentation
Create a pma user and give access to these tables. Documentation
Enable advanced features in configuration file (config.inc.php), for example by starting from config.sample.inc.php. Documentation
Re-login to phpMyAdmin to load the updated configuration file.
Jono.
