Phpmyadmin doesnt work. Please help me
tihp
When I access PhpMyAdmin, it prompts username/pass which I would enter in something like 'domain_admin'/'password'
then the following would show up.
http://65.77.219.37/phpmyadmin_error.jpg
Please note that the username/password must be correct to by pass the popup prompt.
Thank you,
Hieu Pham
If you tried to find phpmyadmin related issues you would find one similar case...
There is a weird php bug for some people with output buffering. By turning it off, it should work. Just paste the following into your command line as root:
code:--------------------------------------------------------------------------------
/usr/bin/perl -pi -e 's/\$mode = 1;/\$mode = 0;/' /var/www/html/phpMyAdmin-2.5.0/libraries/ob.lib.php--------------------------------------------------------------------------------
> http://www.directadmin.com/forum/showthread.php?s=&threadid=719
