[Sun Jan 29 04:20:05 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Jan 29 04:20:05 2012] [warn] Init: SSL server IP/port conflict: www.up.abu-mostfa.com:443 (/usr/local/directadmin/data/$
[Sun Jan 29 04:20:05 2012] [warn] Init: SSL server IP/port conflict: www.abu-mostfa.com:443 (/usr/local/directadmin/data/use$
[Sun Jan 29 04:20:05 2012] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:$
[Sun Jan 29 04:20:05 2012] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Jan 29 04:20:05 2012] [notice] Apache/2.2.21 (Unix) mod_ssl/2.2.21 OpenSSL/0.9.8e-fips-rhel5 DAV/2 PHP/5.2.17 configure$
[Sun Jan 29 06:18:52 2012] [error] [client 127.0.0.1] File does not exist: /var/www/html/pinger, referer: http://rpc.blogrol$
[Sun Jan 29 06:18:52 2012] [warn] [client 127.0.0.1] mod_include: Options +Includes (or IncludesNoExec) wasn't set, INCLUDES$
[Sun Jan 29 07:55:35 2012] [error] [client 207.46.204.180] File does not exist: /home/admin/domains/sharedip/robots.txt
[Sun Jan 29 07:55:35 2012] [error] [client 207.46.204.180] File does not exist: /home/admin/domains/sharedip/404.shtml
[Sun Jan 29 07:56:23 2012] [error] [client 207.46.204.180] File does not exist: /home/admin/domains/sharedip/vb
[Sun Jan 29 07:56:23 2012] [error] [client 207.46.204.180] File does not exist: /home/admin/domains/sharedip/404.shtml
[Sun Jan 29 09:29:02 2012] [error] [client 66.249.71.10] File does not exist: /home/admin/domains/sharedip/robots.txt
[Sun Jan 29 09:29:02 2012] [error] [client 66.249.71.10] File does not exist: /home/admin/domains/sharedip/404.shtml
[Sun Jan 29 11:07:02 2012] [error] [client 50.23.103.74] File does not exist: /home/admin/domains/sharedip/admin
[Sun Jan 29 11:07:02 2012] [error] [client 50.23.103.74] File does not exist: /home/admin/domains/sharedip/404.shtml
[Sun Jan 29 19:01:58 2012] [error] [client 220.181.108.99] File does not exist: /home/admin/domains/sharedip/robots.txt
[Sun Jan 29 19:01:58 2012] [error] [client 220.181.108.99] File does not exist: /home/admin/domains/sharedip/404.shtml
[Sun Jan 29 20:50:21 2012] [error] [client 180.76.5.163] File does not exist: /home/admin/domains/sharedip/robots.txt
[Sun Jan 29 20:50:21 2012] [error] [client 180.76.5.163] File does not exist: /home/admin/domains/sharedip/404.shtml
[Sun Jan 29 22:15:51 2012] [error] [client 127.0.0.1] File does not exist: /var/www/html/pinger, referer: http://rpc.blogrol$
[Sun Jan 29 22:15:51 2012] [warn] [client 127.0.0.1] mod_include: Options +Includes (or IncludesNoExec) wasn't set, INCLUDES$
[Mon Jan 30 00:06:05 2012] [error] [client 127.0.0.1] File does not exist: /var/www/html/pinger, referer: http://rpc.blogrol$
[Mon Jan 30 00:06:05 2012] [warn] [client 127.0.0.1] mod_include: Options +Includes (or IncludesNoExec) wasn't set, INCLUDES$
[Mon Jan 30 00:10:05 2012] [notice] SIGHUP received. Attempting to restart
[Mon Jan 30 00:10:12 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Mon Jan 30 00:10:12 2012] [warn] Init: SSL server IP/port conflict: www.up.abu-mostfa.com:443 (/usr/local/directadmin/data/$
[Mon Jan 30 00:10:12 2012] [warn] Init: SSL server IP/port conflict: www.abu-mostfa.com:443 (/usr/local/directadmin/data/use$
[Mon Jan 30 00:10:12 2012] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:$
[Mon Jan 30 00:10:12 2012] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Mon Jan 30 00:10:13 2012] [notice] Apache/2.2.21 (Unix) mod_ssl/2.2.21 OpenSSL/0.9.8e-fips-rhel5 DAV/2 PHP/5.2.17 configure$
[Mon Jan 30 00:12:01 2012] [notice] caught SIGTERM, shutting down
[Mon Jan 30 00:12:04 2012] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
