Starting DirectAdmin: /usr/local/directadmin/directadmin: error while loading shared libraries: libssl.so.4: cannot open shared object file: No such file or directory
what i have 2 do !? ???
You should be able to symlink that to a simular looking file with a different number. Keep in mind a tempary fix can cause problems in the long run, I would make sure to get the correct OpenSSL package for your OS.
