Please help to Fix Complile Apache 2.4.12
hack3rb43
Thailand
Why when i compile apache have error
acinclude.m4:12: warning: underquoted definition of APACHE_SUBST
acinclude.m4:19: warning: underquoted definition of APACHE_FAST_OUTPUT
acinclude.m4:25: warning: underquoted definition of APACHE_GEN_CONFIG_VARS
acinclude.m4:115: warning: underquoted definition of APACHE_GEN_MAKEFILES
acinclude.m4:122: warning: underquoted definition of APACHE_OUTPUT
acinclude.m4:131: warning: underquoted definition of APACHE_TYPE_RLIM_T
acinclude.m4:154: warning: underquoted definition of APACHE_MODPATH_INIT
acinclude.m4:166: warning: underquoted definition of APACHE_MODPATH_FINISH
acinclude.m4:184: warning: underquoted definition of APACHE_MODPATH_ADD
acinclude.m4:230: warning: underquoted definition of APACHE_MPM_MODULE
acinclude.m4:307: warning: underquoted definition of APACHE_MODULE
acinclude.m4:408: warning: underquoted definition of APACHE_ENABLE_MODULES
acinclude.m4:468: warning: underquoted definition of APACHE_REQUIRE_CXX
acinclude.m4:482: warning: underquoted definition of APACHE_CHECK_OPENSSL
acinclude.m4:603: warning: underquoted definition of APACHE_SUBST_EXPANDED_ARG
acinclude.m4:610: warning: underquoted definition of APACHE_EXPORT_ARGUMENTS
checking for chosen layout... Apache
checking for working mkdir -p... yes
checking for egrep... grep -E
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
configure:
configure: Configuring Apache Portable Runtime library...
configure:
configuring package in srclib/apr now
Configuring APR library
Platform: x86_64-unknown-linux-gnu
APR Version: 1.5.1
checking for chosen layout... apr
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... configure: error: in `/usr/local/directadmin/custombuild/httpd-2.4.12/srclib/apr':
configure: error: cannot run C compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details
configure failed for srclib/apr
My System Centos 5.11 Directadmin 1.48 custombuild2
Pre compile gcc development tool has install
before has complie work correct but now can't
please help to fix
build dovecot
[root@re3 custombuild]# ./build dovecot
File already exists
MD5 Checksum on dovecot-2.2.16.tar.gz passed.
File already exists
MD5 Checksum on dovecot.boot passed.
File already exists
MD5 Checksum on dovecot.boot.freebsd passed.
File already exists
MD5 Checksum on dovecot.boot.debian passed.
File already exists
MD5 Checksum on dovecot.conf passed.
File already exists
MD5 Checksum on exim.conf.dovecot.patch passed.
Installing dovecot 2.2.16 ...
Found /usr/local/directadmin/custombuild/dovecot-2.2.16.tar.gz
Extracting ...
Done.
Patching syslog with LOG_PID ...
Configuring dovecot 2.2.16 ...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for style of include used by make... GNU
checking whether we are cross compiling... configure: error: in `/usr/local/directadmin/custombuild/dovecot-2.2.16':
*** There was an error while trying to configure dovecot. Please check configure/dovecot/configure.dovecot file.
If you give me access to your server via SSH, I could check it for you. Please use PM or Skype to contact me privately.
Did you bother to look in /usr/local/directadmin/custombuild/dovecot-2.2.16/config.log to see what your error was?
[root@re3 ~]# cat /usr/local/directadmin/custombuild/dovecot-2.2.16/config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by Dovecot configure 2.2.16, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ ./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var
## Platform. ##
hostname = re3.hostinglotus.net
uname -m = x86_64
uname -r = 2.6.18-404.el5
uname -s = Linux
uname -v = #1 SMP Tue Apr 7 12:42:54 EDT 2015
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = x86_64
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/kerberos/sbin
PATH: /usr/kerberos/bin
PATH: /usr/local/sbin
PATH: /usr/bin
PATH: /bin
PATH: /usr/sbin
PATH: /sbin
PATH: /usr/local/bin
PATH: /root/bin
## Core tests. ##
configure:2845: checking for a BSD-compatible install
configure:2913: result: /usr/bin/install -c
configure:2924: checking whether build environment is sane
configure:2979: result: yes
configure:3130: checking for a thread-safe mkdir -p
configure:3169: result: /bin/mkdir -p
configure:3176: checking for gawk
configure:3192: found /usr/bin/gawk
configure:3203: result: gawk
configure:3214: checking whether make sets $(MAKE)
configure:3236: result: yes
configure:3265: checking whether make supports nested variables
configure:3282: result: yes
configure:3410: checking whether to enable maintainer-specific portions of Makefiles
configure:3419: result: no
configure:3486: checking for pkg-config
configure:3504: found /usr/bin/pkg-config
configure:3516: result: /usr/bin/pkg-config
configure:3541: checking pkg-config is at least version 0.9.0
configure:3544: result: yes
configure:4367: checking for style of include used by make
configure:4395: result: GNU
configure:4466: checking for gcc
configure:4482: found /usr/bin/gcc
configure:4493: result: gcc
configure:4722: checking for C compiler version
configure:4731: gcc --version >&5
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-55)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4742: $? = 0
configure:4731: gcc -v >&5
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --disable-plugin --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=x86_64-redhat-linux
Thread model: posix
gcc version 4.1.2 20080704 (Red Hat 4.1.2-55)
configure:4731: gcc -V >&5
gcc: '-V' option must have argument
configure:4742: $? = 1
configure:4731: gcc -qversion >&5
gcc: unrecognized option '-qversion'
gcc: no input files
configure:4762: checking whether the C compiler works
configure:4784: gcc conftest.c >&5
configure:4788: $? = 0
configure:4836: result: yes
configure:4839: checking for C compiler default output file name
configure:4841: result: a.out
configure:4847: checking for suffix of executables
configure:4854: gcc -o conftest conftest.c >&5
configure:4858: $? = 0
configure:4880: result:
configure:4902: checking whether we are cross compiling
configure:4910: gcc -o conftest conftest.c >&5
In file included from /usr/include/stdio.h:36,
from conftest.c:12:
/usr/include/bits/types.h:137: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__dev_t'
/usr/include/bits/types.h:138: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__uid_t'
/usr/include/bits/types.h:139: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__gid_t'
/usr/include/bits/types.h:140: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__ino_t'
/usr/include/bits/types.h:141: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__ino64_t'
/usr/include/bits/types.h:142: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__mode_t'
/usr/include/bits/types.h:143: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__nlink_t'
/usr/include/bits/types.h:144: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__off_t'
/usr/include/bits/types.h:145: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__off64_t'
/usr/include/bits/types.h:146: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__pid_t'
/usr/include/bits/types.h:147: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__fsid_t'
/usr/include/bits/types.h:148: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__clock_t'
/usr/include/bits/types.h:149: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__rlim_t'
/usr/include/bits/types.h:150: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__rlim64_t'
/usr/include/bits/types.h:151: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__id_t'
/usr/include/bits/types.h:152: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__time_t'
/usr/include/bits/types.h:153: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__useconds_t'
/usr/include/bits/types.h:154: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__suseconds_t'
/usr/include/bits/types.h:156: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__daddr_t'
/usr/include/bits/types.h:157: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__swblk_t'
/usr/include/bits/types.h:158: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__key_t'
/usr/include/bits/types.h:161: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__clockid_t'
/usr/include/bits/types.h:164: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__timer_t'
/usr/include/bits/types.h:167: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__blksize_t'
/usr/include/bits/types.h:172: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__blkcnt_t'
/usr/include/bits/types.h:173: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__blkcnt64_t'
/usr/include/bits/types.h:176: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__fsblkcnt_t'
/usr/include/bits/types.h:177: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__fsblkcnt64_t'
/usr/include/bits/types.h:180: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__fsfilcnt_t'
/usr/include/bits/types.h:181: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__fsfilcnt64_t'
/usr/include/bits/types.h:183: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__ssize_t'
/usr/include/bits/types.h:187: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__loff_t'
In file included from /usr/include/libio.h:32,
from /usr/include/stdio.h:72,
from conftest.c:12:
/usr/include/_G_config.h:28: error: expected specifier-qualifier-list before '__off_t'
/usr/include/_G_config.h:33: error: expected specifier-qualifier-list before '__off64_t'
In file included from /usr/include/stdio.h:72,
from conftest.c:12:
/usr/include/libio.h:297: error: expected specifier-qualifier-list before '__off_t'
/usr/include/libio.h:361: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__io_read_fn'
/usr/include/libio.h:369: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__io_write_fn'
/usr/include/libio.h:378: error: expected declaration specifiers or '...' before '__off64_t'
/usr/include/libio.h:485: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_padn'
/usr/include/libio.h:488: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_seekoff'
/usr/include/libio.h:489: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_seekpos'
In file included from conftest.c:12:
/usr/include/stdio.h:674: error: expected declaration specifiers or '...' before '__off_t'
/usr/include/stdio.h:679: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ftello'
configure:4914: $? = 1
configure:4921: ./conftest
./configure: line 4923: ./conftest: No such file or directory
configure:4925: $? = 127
configure:4932: error: in `/usr/local/directadmin/custombuild/dovecot-2.2.16':
configure:4934: error: cannot run C compiled programs.
## Cache variables. ##
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CLUCENE_CFLAGS_set=
ac_cv_env_CLUCENE_CFLAGS_value=
ac_cv_env_CLUCENE_LIBS_set=
ac_cv_env_CLUCENE_LIBS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_PKG_CONFIG_LIBDIR_set=
ac_cv_env_PKG_CONFIG_LIBDIR_value=
ac_cv_env_PKG_CONFIG_PATH_set=
ac_cv_env_PKG_CONFIG_PATH_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_SSL_CFLAGS_set=
ac_cv_env_SSL_CFLAGS_value=
ac_cv_env_SSL_LIBS_set=
ac_cv_env_SSL_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
am_cv_make_support_nested_variables=yes
## Output variables. ##
ACLOCAL='${SHELL} /usr/local/directadmin/custombuild/dovecot-2.2.16/missing aclocal-1.14'
ACLOCAL_AMFLAGS='-I $(top_srcdir)'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='1'
AM_V='$(V)'
AR=''
AUTH_CFLAGS=''
AUTH_LIBS=''
AUTOCONF='${SHELL} /usr/local/directadmin/custombuild/dovecot-2.2.16/missing autoconf'
AUTOHEADER='${SHELL} /usr/local/directadmin/custombuild/dovecot-2.2.16/missing autoheader'
AUTOMAKE='${SHELL} /usr/local/directadmin/custombuild/dovecot-2.2.16/missing automake-1.14'
AWK='gawk'
BUILD_DOCS_FALSE='#'
BUILD_DOCS_TRUE=''
BUILD_LUCENE_EXTTEXTCAT_FALSE=''
BUILD_LUCENE_EXTTEXTCAT_TRUE=''
BUILD_LUCENE_FALSE=''
BUILD_LUCENE_STEMMER_FALSE=''
BUILD_LUCENE_STEMMER_TRUE=''
BUILD_LUCENE_TEXTCAT_FALSE=''
BUILD_LUCENE_TEXTCAT_TRUE=''
BUILD_LUCENE_TRUE='#'
BUILD_MYSQL_FALSE=''
BUILD_MYSQL_TRUE=''
BUILD_OPENSSL_FALSE=''
BUILD_OPENSSL_TRUE=''
BUILD_PGSQL_FALSE=''
BUILD_PGSQL_TRUE=''
BUILD_SHARED_LIBS_FALSE='#'
BUILD_SHARED_LIBS_TRUE=''
BUILD_SOLR_FALSE=''
BUILD_SOLR_TRUE=''
BUILD_SQLITE_FALSE=''
BUILD_SQLITE_TRUE=''
BUILD_ZLIB_PLUGIN_FALSE=''
BUILD_ZLIB_PLUGIN_TRUE=''
CC='gcc'
CCDEPMODE=''
CDB_LIBS=''
CFLAGS=''
CLUCENE_CFLAGS=''
CLUCENE_LIBS=''
COMPRESS_LIBS=''
CPP=''
CPPFLAGS=''
CRYPT_LIBS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DEFS=''
DEPDIR='.deps'
DICT_LIBS=''
DLLTOOL=''
DOVECOT_PLUGIN_DEPS_FALSE=''
DOVECOT_PLUGIN_DEPS_TRUE=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
FGREP=''
GREP=''
GSSAPI_PLUGIN_FALSE=''
GSSAPI_PLUGIN_TRUE=''
HAVE_RQUOTA_FALSE=''
HAVE_RQUOTA_TRUE=''
HAVE_SYSTEMD_FALSE=''
HAVE_SYSTEMD_TRUE='#'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
KRB5CONFIG=''
KRB5_CFLAGS=''
KRB5_LIBS=''
LD=''
LDAP_LIBS=''
LDAP_PLUGIN_FALSE=''
LDAP_PLUGIN_TRUE=''
LDFLAGS=''
LIBCAP=''
LIBDOVECOT=''
LIBDOVECOT_COMPRESS=''
LIBDOVECOT_DEPS=''
LIBDOVECOT_DSYNC=''
LIBDOVECOT_LDA=''
LIBDOVECOT_LOGIN=''
LIBDOVECOT_SQL=''
LIBDOVECOT_STORAGE=''
LIBDOVECOT_STORAGE_DEPS=''
LIBICONV=''
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIBWRAP_LIBS=''
LINKED_STORAGE_LDADD=''
LINKED_STORAGE_LIBS=''
LIPO=''
LN_S=''
LTLIBICONV=''
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='${SHELL} /usr/local/directadmin/custombuild/dovecot-2.2.16/missing makeinfo'
MANIFEST_TOOL=''
MKDIR_P='/bin/mkdir -p'
MODULE_LIBS=''
MODULE_SUFFIX=''
MYSQL_CFLAGS=''
MYSQL_CONFIG=''
MYSQL_LIBS=''
NM=''
NMEDIT=''
NOPLUGIN_LDFLAGS=''
OBJDUMP=''
OBJEXT=''
OTOOL64=''
OTOOL=''
PACKAGE='dovecot'
PACKAGE_BUGREPORT='[email protected]'
PACKAGE_NAME='Dovecot'
PACKAGE_STRING='Dovecot 2.2.16'
PACKAGE_TARNAME='dovecot'
PACKAGE_URL=''
PACKAGE_VERSION='2.2.16'
PATH_SEPARATOR=':'
PGSQL_CFLAGS=''
PGSQL_LIBS=''
PG_CONFIG=''
PKG_CONFIG='/usr/bin/pkg-config'
PKG_CONFIG_LIBDIR=''
PKG_CONFIG_PATH=''
QUOTA_LIBS=''
RANLIB=''
RPCGEN=''
RUN_TEST=''
SED=''
SETTING_FILES=''
SET_MAKE=''
SHELL='/bin/sh'
SQLITE_CFLAGS=''
SQLITE_LIBS=''
SQL_CFLAGS=''
SQL_LIBS=''
SQL_PLUGINS_FALSE=''
SQL_PLUGINS_TRUE=''
SSL_CFLAGS=''
SSL_LIBS=''
STRIP=''
TCPWRAPPERS_FALSE=''
TCPWRAPPERS_TRUE=''
VALGRIND=''
VERSION='2.2.16'
abs_top_builddir=''
ac_ct_AR=''
ac_ct_CC='gcc'
ac_ct_CXX=''
ac_ct_DUMPBIN=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build=''
build_alias=''
build_cpu=''
build_os=''
build_vendor=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
dict_drivers=''
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /usr/local/directadmin/custombuild/dovecot-2.2.16/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='/var'
mail_storages='shared mdbox sdbox maildir mbox cydir imapc pop3c raw fail'
mailbox_list_drivers=''
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
moduledir='${exec_prefix}/lib/dovecot'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/usr'
program_transform_name='s,x,x,'
psdir='${docdir}'
rundir='/var/run/dovecot'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sql_drivers=''
ssldir='/etc/ssl'
statedir='/var/lib/dovecot'
sysconfdir='/etc'
systemdsystemunitdir=''
target_alias=''
## confdefs.h. ##
/* confdefs.h */
#define PACKAGE_NAME "Dovecot"
#define PACKAGE_TARNAME "dovecot"
#define PACKAGE_VERSION "2.2.16"
#define PACKAGE_STRING "Dovecot 2.2.16"
#define PACKAGE_BUGREPORT "[email protected]"
#define PACKAGE_URL ""
#define DOVECOT_ABI_VERSION "2.2.ABIv16(2.2.16)"
#define PACKAGE "dovecot"
#define VERSION "2.2.16"
configure: exit 1
It doesn't really make sense from what I see. It looks like it is complaining about the:
__STD_TYPE
macro in types.h and that gets set earlier in that file based on the value of __WORDSIZE (32/64). __WORDSIZE should have been set from the #include <bits/wordsize.h> earlier in types.h, and that sets it based on the value of __x86_64__ which should be defined in gcc (gcc -dM -E - < /dev/null |grep x86 )
I don't have a CentOS/RHEL 5 system to test this with, but something seems to be messed up with that build system. Have you been able to build dovecot and other applications in the past on this server?
__STD_TYPE
[root@re3 week]# gcc -dM -E - < /dev/null |grep x86
#define __x86_64 1
#define __x86_64__ 1
[root@re3 week]#
This now my server can't compile any sorcecode
error with same thing
