Pleass help
TestUser
First i ulgraded sxi to last version
Then problems with emails. Started
Downgraded exim...
Nkw i just saw this in messages
This is an automated message notifying you that an error has occurred while trying to update the software.
The generated error message is as follows:
signal: terminated
Please contact JBMC-Software, including the error message. Failure to do so could result in an inactive control panel.
I did buiild but i see some. Error. About broken. Packages
And have problems with sebding emails
Some. /etc/virtual permissions problems
I did run the fix script... But peoblems persist.
Hiw can i get help?
Support helped me...so server is running... and they say update also on the way :D
