plz help : exim problem
mymy
hello
i have problem with smtp
exim is stoped and i have bellow error in error log :
Jun 18 20:40:08 CentOS-55-32-minimal dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=15435, secured
Jun 18 20:40:08 CentOS-55-32-minimal dovecot: auth: passwd([email protected],127.0.0.1): unknown user
Jun 18 20:40:08 CentOS-55-32-minimal dovecot: auth: shadow([email protected],127.0.0.1): unknown user
Jun 18 20:40:10 CentOS-55-32-minimal dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=15437, secured
Jun 18 20:40:10 CentOS-55-32-minimal dovecot: auth: passwd([email protected],127.0.0.1): unknown user
Jun 18 20:40:10 CentOS-55-32-minimal dovecot: auth: shadow([email protected],127.0.0.1): unknown user
Jun 18 20:40:10 CentOS-55-32-minimal dovecot: imap([email protected]): Disconnected: Logged out bytes=417/1672
Jun 18 20:40:10 CentOS-55-32-minimal dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=15439, secured
Jun 18 20:40:10 CentOS-55-32-minimal dovecot: imap([email protected]): Disconnected: Logged out bytes=300/2343
Jun 18 20:48:16 CentOS-55-32-minimal dovecot: auth: shadow([email protected],127.0.0.1): unknown user
Jun 18 20:48:16 CentOS-55-32-minimal dovecot: auth: passwd([email protected],127.0.0.1): unknown user
Jun 18 20:48:16 CentOS-55-32-minimal dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=16244, secured
Jun 18 20:48:16 CentOS-55-32-minimal dovecot: imap([email protected]): Disconnected: Logged out bytes=85/716
Jun 18 21:59:59 server dovecot: master: Dovecot v2.0.11 starting up (core dumps disabled)
Jun 18 22:06:20 server dovecot: auth: shadow([email protected],127.0.0.1): unknown user
Jun 18 22:06:20 server dovecot: auth: passwd([email protected],127.0.0.1): unknown user
Jun 18 22:06:20 server dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=2145, secured
Jun 18 22:06:20 server dovecot: imap([email protected]): Disconnected: Logged out bytes=300/2343
Jun 18 22:06:20 server dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=2147, secured
Jun 18 22:06:20 server dovecot: imap([email protected]): Disconnected: Logged out bytes=85/716
Jun 18 22:06:24 server dovecot: auth: shadow([email protected],127.0.0.1): unknown user
Jun 18 22:06:24 server dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=2149, secured
Jun 18 22:06:24 server dovecot: auth: passwd([email protected],127.0.0.1): unknown user
Jun 18 22:06:25 server dovecot: imap([email protected]): Disconnected: Logged out bytes=149/5203
Jun 18 22:06:28 server dovecot: auth: shadow([email protected],127.0.0.1): unknown user
Jun 18 22:06:28 server dovecot: auth: passwd([email protected],127.0.0.1): unknown user
Jun 18 22:06:28 server dovecot: imap([email protected]): Disconnected: Logged out bytes=300/2343
Jun 18 22:06:28 server dovecot: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=2151, secured
Jun 18 22:26:48 server dovecot: master: Warning: Killed with signal 15 (by pid=9762 uid=0 code=kill)
Jun 18 22:26:48 server dovecot: master: Dovecot v2.0.11 starting up (core dumps disabled)
dovecot and exim are two different daemons, and one has nothing to do with the error.
Check your exim logs.
Restart exim for a root shell and see what error(s) you get:
# service exim restart
