PMA Database ... not OK [ Documentation ] General relation features Disabled
beetle
nethetlands
PhpMyAdmin workt, but when i will try to create a table, it don't work. ik don't get an error but only a red empty balk...
below the homepage of myadmin is : The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. To find out why click here.
when i click it gives: PMA Database ... not OK [ Documentation ] General relation features Disabled
last days i have update php from 5.2 -> 5.3 -> 5.4
i think it is because the update, but i am not real sure, because i didn't test phpMyAdmin before the update..
I have empty al cookies of my home pc..
above is solved by:
http://help.directadmin.com/item.php?id=564
but my problem is not solved?????
when i will create a table i can fill in table name's but when i will save, it gives only a red line with on the left an exclamation mark
and i got a second problem???
i cant select the database i want???? when i will select a database, it goes everytime back to everytime the same database???
Wich version of phpMyAdmin are you running? Make sure you are running the newest version. You should check the setting in this file:
usr/local/directadmin/custombuild/options.conf
Make sure you have a line in options.conf that say:
phpmyadmin_ver=4
If not change to that in options.conf and run:
./build phpmyadmin
i have the newest version of phpMyAdmin ( newest from custumbuild ) reboot serveral times, and now i put my snapshot back from before i did http://help.directadmin.com/item.php?id=564
the problem is i can't create tables, it dont give any error but only a red line..
when i will try to create a table directly in SQL it give the following error:
import.php: Missing parameter: import_typeDocumentation
import.php: Missing parameter: formatDocumentation
hole evening search on google don't give me the solution..
i think it must be a result of the update from php5.2 -> 5.4
Oups i miss to say: check your php build conf.
Before my update i compile php with pdo, and when i update i have same error because php build without pdo. I recompile php with custombuild after add my config in conf file, and that work fine.
That not come from phpmyadmin.
I try to do it with
Add the next in the custombuild config php5
PHP:
--enable-pdo=shared /
--with-pdo-mysql=shared /
--with-sqlite=shared /
--with-pdo-sqlite=shared /
./build clean
./build php n
but that gives not the result i want??
Is this the way u did it?
I add what i have in php conf before update, before update i have :
--with-pdo \
--enable-pdo \
--with-pdo-mysql=mysqlnd \
--with-sqlite \
--with-pdo-sqlite \
So I add this in php conf before built it, but perhaps in not same for you, check your previous conf.
Thanks..
I have to look further.
now
i can't import SQL it gives
even by very smal queries..
and i can't create manual tables or coloms :(
