KingEZFLOW
- Aug 2, 2024
Sorry if I posted this in the wrong category
It won't let me, as shown in the screenshot it shows that the IP is not active for DA, and there's no button anywhere to "remove" the IP. only to enable it and disable it. And the IP is active even though it shows that it's not because if I go to XX.XX.XX.14:2222 it goes to the admin panel.If you don't want to have this used this at all by DA, why don't you just delete it via the ip manager?
Normally that should be possible.
Wouldn’t that remove it entirely from my server? As I want to use the IP for Discourse. While running both DA and Discourse on the same machine.If you remove it from the interface via bash and restart networking..., can you delete it from DA then?
Not trying to bind DA to an IP, trying to make it not listen/unbind a specific IPFeature available is only bind 1 IPs.
It was just a suggestion to see if you can delete it in DA after you've removed it from the interface, you can add it back after.Wouldn’t that remove it entirely from my server? As I want to use the IP for Discourse. While running both DA and Discourse on the same machine.
Yes if you remove it from the network interface yes. You might want to test switching to the Enhanced skin temporarily as normally you can remove there the ip addresses. Just do not choice "remove from device".Wouldn’t that remove it entirely from my server?
/usr/local/directadmin/data/admin/ip.list
file and remove the ip from there./usr/local/directadmin/data/admin/ips
directory and remove the ip from there too.
