Problem after change licence
I used this help to change my license.
http://help.directadmin.com/item.php?id=30
The trouble is that now I no longer have access to directadmin via ssh
I'm confused. You don't access DirectAdmin through a shell login. You access your server through a command login. If you can no longer login through a shell, then that's got nothing to do with your DirectAdmin license.
and I fail to see the key (* You are not allowed to run this program *)
I'm not sure where you expect to see this. Exactly what are you doing when you see or don't see this?
Where is the mistake?
Thanks[/QUOTE]
