Problem building with mssql support
davidb
I had php 5.2 on a hosting box and just did the upgrade to 5.4. Now mssql support is not being enabled.
Suggesitons or ideas?
some guidance? I have already updated the custom/ap2/configure.php5 custom/php5/configure.php5 and custom/suphp/configure.php5 files..
I modified configure/ap2/configure.php54.
Looks like that is the magic..
You should copy configure/ap2/configure.php54 to custom/ap2/configure.php54, otherwise you'll loose your modifications.
