problem. Can't start directadmin
Status
Not open for further replies.
urgido
MX
Hi people.
I have a big problem. I can't start DA.
./directadmin start
Starting DirectAdmin: [ OK ]
but it's down.
/var/log/directadmin/error.log it's empty.
I need help, pls.:confused::confused::confused::confused:
may 28 03:21:33 blazer kernel: [ 1033.114295] firewall: *tcp_in blocked* in=eth0 out= mac=00:1b:b9:6b:6f:b4:00:13:5f:31:57:4a:08:00 src=58.160.80.16 dst=66.197.206.178 len=48 t$
may 28 03:21:33 blazer kernel: [ 1033.116713] firewall: *tcp_in blocked* in=eth0 out= mac=00:1b:b9:6b:6f:b4:00:13:5f:31:57:4a:08:00 src=58.160.80.16 dst=66.197.206.180 len=48 t$
may 28 03:21:33 blazer kernel: [ 1033.117526] firewall: *tcp_in blocked* in=eth0 out= mac=00:1b:b9:6b:6f:b4:00:13:5f:31:57:4a:08:00 src=58.160.80.16 dst=66.197.206.181 len=48 t$
may 28 03:21:33 blazer kernel: [ 1033.118337] firewall: *tcp_in blocked* in=eth0 out= mac=00:1b:b9:6b:6f:b4:00:13:5f:31:57:4a:08:00 src=58.160.80.16 dst=66.197.206.179 len=48 t$
may 28 03:21:33 blazer kernel: [ 1033.120702] firewall: *tcp_in blocked* in=eth0 out= mac=00:1b:b9:6b:6f:b4:00:13:5f:31:57:4a:08:00 src=58.160.80.16 dst=66.197.206.183 len=48 t$
may 28 03:21:36 blazer kernel: [ 1036.349411] firewall: *tcp_in blocked* in=eth0 out= mac=00:1b:b9:6b:6f:b4:00:13:5f:31:57:4a:08:00
i use csf lfd
strange problem.
People of other countries can see all my hosted sites but people of my country (Mexico) can't see my hosted sites.
Very strange. I need help, pls
CSF AND LFD STOPPED
I CAN CONNECT USING IP BUT NOT DNS. example i can connect 85.66.XXX.00 but not mydomain.com
And we can't help you because you don't want us to know your IP#. Since the problem is with DNS we need to know domain names and what the IP# should be.
My nameservers are set in godaddy
main 96.9.147.149
some domains:
Ruiverfvv.com
piensahosting.com
enmueblate.mx
grupoiesa.com
nameservers:
Ns1.piensahosting.info -> 96.9.147.149
ns2.piensahosting.info -> 96.9.147.150
tks
Please do not give us incorrect information; none of those domains are at 69.9.147.149:
$ dig ruiverfvv.com +short
66.197.206.182
$ dig piensahosting.com +short
96.9.147.151
$ dig enmueblate.mx +short
96.9.147.152
$ dig grupoiesa.com +short
96.9.147.153
These all work from here. If they don't work from within Mexico then the problem is not with your server but rather some kind of routing issue within Mexico.
all information is correct, I talk about my main ip. This sites are hosted on my server with differents ips. I have around 28 usable ips.
BTW, Can you see the sites?
Yes, I can see the sites. That's what I meant when I wrote: These all work from here.
Status
