linusanderas
- Nov 8, 2008
I get the following response when I create a certificate for my domain.
But when I surf to https://tryggwifi.se I get a certificate-error because the certificate is only including my main-domain-name. And when I watch timestamps on the files
/etc/httpd/conf/ssl.crt/server.crt
/etc/httpd/conf/ssl.key/server.key
I can se that they have not been modified.
Any suggestions on where to start troubleshooting?
Getting challenge for tryggwifi.se from acme-server...
Waiting for domain verification...
Challenge is valid.
Getting challenge for www.tryggwifi.se from acme-server...
Challenge is valid.
Generating 4096 bit RSA key for tryggwifi.se...
openssl genrsa 4096 > "/usr/local/directadmin/data/users/admin/domains/tryggwifi.se.key.new"
Generating RSA private key, 4096 bit long modulus
e is 65537 (0x10001)
Certificate for tryggwifi.se has been created successfully!
NOTE: You are using the server IP, so your certificate and key have been saved to:
NOTE: You are using the server IP, so your CA Root Certificate has been saved to:
/etc/httpd/conf/ssl.crt/server.ca
