problem dataskq
groomy
AUGNY (France)
Hello, I get emails from one hour every 5 minutes.
/usr/local/directadmin/dataskq: error while loading shared libraries: libssl.so.10: cannot open shared object file: No such file or directory
when I want to manually restart directadmin I have this message:
/etc/init.d/directadmin restart
Stopping DirectAdmin: [ OK ]
Starting DirectAdmin: /usr/local/directadmin/directadmin: error while loading shared libraries: libssl.so.10: cannot open shared object file: No such file or directory
[FAILED]
lalalala I think I made ​​a mistake!
I reinstall directadmin ssh and nothing works. I came over me Sign in directadmin. login or password not correct password.
All sites are hs
Please help me ... :(
i have in
var/lib/mysql
this files
RPM_UPGRADE_HISTORY
and in
MySQL RPM upgrade to version 5.1.65-1.glibc23
'pre' step running at Mon Sep  3 21:08:51 CEST 2012
ERR file(s):
-rw-rw---- 1 mysql root  535 Jul 13 16:35 /var/lib/mysql/stock.ovh.net.err
-rw-rw---- 1 mysql root 1703 Sep  3 21:08 /var/lib/mysql/ns3002026.ovh.net.err
Latest 'Version' line in latest file:
Version: '5.0.51a-community'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MySQL Community Edition (GPL)
PID file:
ls: /var/lib/mysql/*.pid: No such file or directory
Upgrade/install finished at Mon Sep  3 21:08:52 CEST 2012
MySQL RPM upgrade to version 5.1.73-1.glibc23
'pre' step running at Wed Dec 11 23:19:42 CET 2013
ERR file(s):
-rw-rw---- 1 mysql mysql   535 Jul 13  2012 /var/lib/mysql/stock.ovh.net.err
-rw-rw---- 1 mysql mysql 10902 Dec 11 23:19 /var/lib/mysql/ns3002026.ovh.net.err
Version: '5.1.65'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MySQL Community Server (GPL)
PID file:
Upgrade/install finished at Wed Dec 11 23:19:43 CET 2013
it's not because after i have a old version :confused:
Reinstall DirectAdmin on a DirectAdmin-alredy-installed server is definitly a bad idea, never do that.
I suppose will be needed an huge work to fix everything...
Important thing, does users still exist on DirectAdmin? Are you sure you're having trouble just with MySQL?
Regards
