Problem in HTTPD
3245
Hello
i have problem in httpd
my server HDD was full, i find largest folder and remove it then creat it
"/home/xxxxxx/Maildir/new" folder "new" was 33GB,
now when i do restart httpd i see following error:
[root@mail Maildir]# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: [Wed Jun 19 13:15:13 2013] [warn] The Alias directive in /etc/httpd/conf/httpd.conf at line 148 will probably never match because it overlaps an
earlier Alias.
line 148 is:
147 # Alias for RoundCube webmail
148 Alias /roundcube /var/www/html/roundcube/
now i can not open website, when open site's, i see white page, so httpd is not running
how i can resolve this issue?
some last line is following: nano /var/log/httpd/error_log
[Wed Jun 19 13:15:14 2013] [warn] Init: SSL server IP/port conflict: www.xxxxxx.com:443 (/usr/local/directadmin/data/users/userxxx/httpd.conf:65) vs. www.su$
[Wed Jun 19 13:15:14 2013] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.sub.xxxxx.com:443 (/$
[Wed Jun 19 13:15:14 2013] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Jun 19 13:15:14 2013] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Jun 19 13:15:15 2013] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Wed Jun 19 13:15:15 2013] [warn] Init: SSL server IP/port conflict: www.xxxxxx.com:443 (/usr/local/directadmin/data/users/xxxxxxx/httpd.conf:65) vs. www.su$
[Wed Jun 19 13:15:15 2013] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.sub.xxxxxxx.com:443 (/$
[Wed Jun 19 13:15:15 2013] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Jun 19 13:15:15 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/0.9.8e-fips-rhel5 DAV/2 PHP/5.2.17 configured -- resuming normal operations
[Wed Jun 19 13:15:26 2013] [error] [client 70.117.28.198] File does not exist: /var/www/html/judge-server
[Wed Jun 19 13:15:26 2013] [error] [client 70.117.28.198] File does not exist: /var/www/html/404.shtml
[Wed Jun 19 13:22:12 2013] [error] [client 213.228.151.36] File does not exist: /var/www/html/proxy
[Wed Jun 19 13:22:12 2013] [error] [client 213.228.151.36] File does not exist: /var/www/html/404.shtml
[Wed Jun 19 13:24:50 2013] [error] [client 192.163.204.46] File does not exist: /var/www/html/gp
[Wed Jun 19 13:24:50 2013] [error] [client 192.163.204.46] File does not exist: /var/www/html/404.shtml
[Wed Jun 19 13:27:44 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/forum-78-1.html, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:44 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/404.shtml, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:45 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/forum-37-1.html, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:45 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/404.shtml, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:46 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/forum-97-1.html, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:46 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/404.shtml, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:48 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/thread-60938-1-1.html, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:48 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/404.shtml, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:49 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/thread-60923-1-1.html, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:49 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/404.shtml, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:50 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/thread-60504-1-1.html, referer: http://tieba.baidu.com/
[Wed Jun 19 13:27:50 2013] [error] [client 91.121.170.102] File does not exist: /var/www/html/404.shtml, referer: http://tieba.baidu.com/
[Wed Jun 19 13:31:09 2013] [error] [client 216.12.212.210] File does not exist: /var/www/html/proxy
[Wed Jun 19 13:31:09 2013] [error] [client 216.12.212.210] File does not exist: /var/www/html/404.shtml
[Wed Jun 19 13:34:22 2013] [error] [client 174.139.43.42] File does not exist: /var/www/html/jw!JlCAqOGCBQUf1r.KJ077jUpXwOg-
[Wed Jun 19 13:34:22 2013] [error] [client 174.139.43.42] File does not exist: /var/www/html/404.shtml
[Wed Jun 19 13:34:23 2013] [error] [client 174.139.43.42] File does not exist: /var/www/html/jw!JlCAqOGCBQUf1r.KJ077jUpXwOg-
[Wed Jun 19 13:34:23 2013] [error] [client 174.139.43.42] File does not exist: /var/www/html/404.shtml
Please Help us.
Did you change the httpd.conf yourself or something? Because this is not standard.
Are you using custombuild and apache 2.x?
If yes, line 147 and 148 should not be present in httpd.conf there should only be this a lot higher.
<IfModule alias_module>
    # Include some DirectAdmin alias
    Include conf/extra/httpd-alias.conf
</IfModule>
That's why you got the error notice.
The roundclubeline on your line 148 should be present in /etc/httpd/conf/extra/httpd-alias.conf
If you remove those lines (147 and 148) from your httpd.conf and restart httpd you should be fine.
As for the errors in the log, you can ignore them, that's normal for DA.
