Hello
I have a problem logging to my DA, when I enter a username/password I receive the same page again!
I tried user login, admin login with no luck.
Error log from /var/log/directadmin/error.log
Any help please?
Thank you
2008:02:20-19:30:45: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2008:02:20-19:30:45: Error while sending ./data/skins/enhanced/images/header.gif
2008:02:20-19:32:20: Timeout from from [MY-IP] : last flagged: Request::readAndProcess(*skt, [MY-IP], [MY-IP])
2008:02:20-19:55:24: Auth::passValid: unable to get user_info for Please enter your Username and Password
2008:02:26-14:25:43: The username hasn't been set. Won't run the script without dropping privileges
Any help please?
Thank you
