Problem installing backups
szaad
hi
I have a new server vps
I have a full copy Backups of the site tried to install directadmin
But failed in each attempt :confused:
Is there a script is putting together through ssh :o
What is the best way for the installation of without problems ? :)
Waiting for a reply and
thank you
You are already using a script to install DirectAdmin through SSH. That is the only way to do it.
If you are having problems installing then you must post the error messages. We are not mind readers.
The other recourse is to hire someone to install it for you.
So far there is no clear answer from fellow members :o
I hope that people understand answer clearly
Thank you for your cooperation
Don't forget you need a DirectAdmin license for the IP# on which you're running the VPS. You may need to contact DirectAdmin Sales.
