Hi
I have the following issue trying to install curl.
Does anybody has the same issue?
- Downloading curl-7.79.1.tar.gz...
- --2021-09-29 04:55:13-- https://files-ca.directadmin.com/services/custombuild/curl-7.79.1.tar.gz
- Resolving files-ca.directadmin.com (files-ca.directadmin.com)... 51.161.40.239, 2607:5300:60:1eb6::16
- Connecting to files-ca.directadmin.com (files-ca.directadmin.com)|51.161.40.239|:443... failed: Connection refused.
- Connecting to files-ca.directadmin.com (files-ca.directadmin.com)|2607:5300:60:1eb6::16|:443... failed: Network is unreachable.
- Downloaded file /usr/local/directadmin/custombuild/curl-7.79.1.tar.gz does not exist or is empty after download
- cwd is: /usr/local/directadmin/custombuild
- [1mFileserver might be down, using the backup file server..(B[m
- --2021-09-29 04:55:13-- http://69.162.69.58/services/custombuild/curl-7.79.1.tar.gz
- Connecting to 69.162.69.58:80... failed: Connection timed out.
- Retrying.
- --2021-09-29 04:55:19-- (try: 2) http://69.162.69.58/services/custombuild/curl-7.79.1.tar.gz
- Retrying.
- --2021-09-29 04:55:26-- (try: 3) http://69.162.69.58/services/custombuild/curl-7.79.1.tar.gz
- Giving up.
- [1m*** MD5 Checksum for curl-7.79.1.tar.gz failed *again*.***(B[m
- The md5 checksum value may be incorrect, or a wrong file is being downloaded.
- Install continuing with this possibly corrupted file. (it may also be fine)
- *** Cannot find /usr/local/directadmin/custombuild/curl-7.79.1.tar.gz. Aborting ***
- Done!
