nobaloney
Installing proftpd on 32-bit CentOS6 gave me a problem; it wouldn't install the startup file at /etc/rc.d/init.d/proftpd.
I copied one over from another system, then ran chkconfig with options as required to start up only in runlevel 3, and it works.
But surely this is a problem with something not properly installed in the custombuild scripts?
I saw the problem in other locations on these forums, with 64-bit versions and other CentOS versions, but none of the fixes (which involved changes to proftpd.conf and reinstalling through custombuild) solved the problem.
Has anyone else seen these problems? If so, how have you resolved them?
Thanks.
Thanks.
