As I was fallowing instructions ditto wrote, i faced problem on 2nd step - recompiling apache:
I keep getting same output:
Any ideas why is it so?
#/usr/local/directadmin/custombuild/build apache y
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/metadata'
make[3]: Nothing to be done for `local-all'.
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/metadata'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/metadata'
Making all in proxy
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/proxy'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/proxy'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/proxy'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/proxy'
Making all in ssl
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/ssl'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/ssl'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/ssl'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/ssl'
Making all in http
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/http'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/http'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/http'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/http'
Making all in dav/main
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/main'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/main'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/main'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/main'
Making all in generators
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/generators'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/generators'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/generators'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/generators'
Making all in dav/fs
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/fs'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/fs'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/fs'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/fs'
Making all in dav/lock
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/lock'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/lock'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/lock'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/dav/lock'
Making all in mappers
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/mappers'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/mappers'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/mappers'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules/mappers'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.2.22/modules'
Making all in support
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/support'
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.2.22/support'
/usr/local/directadmin/custombuild/httpd-2.2.22/srclib/apr/libtool --silent --mode=link gcc -g -O2 -pthread -I/usr/local/include -L/usr/local/lib -L/usr/lib -L/usr/kerberos/lib -o htpasswd htpasswd.lo -lm -L/usr/local/lib -lpcre /usr/local/directadmin/custombuild/httpd-2.2.22/srclib/apr-util/libaprutil-1.la -lexpat -liconv /usr/local/directadmin/custombuild/httpd-2.2.22/srclib/apr/libapr-1.la -luuid -lrt -lcrypt -lpthread -ldl -lcrypt
